lift kits
Old 07-08-2007, 12:02 AM
redneck rebel's Avatar
lift kits
i was just wondering if anyone know about what it costs for a kelderman lift on a 2500 ram.
Old 07-08-2007, 06:33 AM
Winner winner chicken dinner!
RyeThomas's Avatar
Not tobe a smart aleck, but change the title to Kelderman lift question. There are only a few members on the entire board that have one of these, so you gotta get their attention. All I know is they are expensive, but they are also show stoppers. Good luck.
Old 07-08-2007, 10:25 AM
Jeff K's Avatar
Th kelderman lifts are roughly $6k base, then you add shocks, air management system, etc, and you are around $10k + installation.
Old 07-09-2007, 11:01 AM
motrapper's Avatar
go with KORE i have the recon and very happy 2.5 to 3 up front and additional 1 in the rear good for 35s dick cepek FCll
Old 07-09-2007, 12:36 PM
DECEPTiON21's Avatar
I just went through this on my truck. If you want a suspension system that will give better ride and enough lift to fit 35s, go with Carli, Thuren, or Lorenz. KORE is overpriced. If you just want lift, go with an off the shelf kit like Fabtech or Superlift (with Thuren springs). BDS is a compromise between lift and suspension.
Old 07-09-2007, 06:08 PM
white06's Avatar
i have a 6 in. bds on mine with 37in. tires it rides decent , but it is a truck .
Old 07-10-2007, 10:14 PM
chico01's Avatar
I also have 35s FCII on stock rims and I am not happy with the tires. The FCII on 17 inch rims are very soft sidewalled for such a heavy truck, plus I also tow an 7000 lbs trailer. My next purchase will be either E rated Toyos or go to a 20 inch rim or both.
Old 07-11-2007, 07:07 PM
jamesbfishin's Avatar
Do the Cepek mud t/a's have a soft sidewall too or is it just the FCII, I've been eyeing up the 305's
Old 07-12-2007, 01:34 PM
chico01's Avatar
Couldn't tell you for sure without seeing them, but I'm sure you'll be alright. Those 305's are E rated and the stronger sidewalls can hold higher air pressure.
Old 07-12-2007, 03:36 PM
motrapper's Avatar
i have the 265 70 17 on my dually and they work well they have 3 ply side walls and wear very well but iam interested in the comment about soft side walls on the fc11 had a set of 285 75 16 on my f350 and they towed and wore like iron did you run them less then max air preasure
Old 07-13-2007, 01:57 PM
chico01's Avatar
Max is 50 psi, I run 47-48psi. I would assume sidewall deflection is much greater on my 35s than on 285-75. They are are okay tire, but 35 on 17 rims were probably meant to be used on a lifted Jeep or other vehicles much lighter than our trucks. If I stay with the stock rims, next purchase will be 35s that are E rated tires.
TheNeckasaurus
10-13-2010 08:16 PM
customizedcreat
05-19-2010 01:44 PM
LLoTuner
04-09-2008 11:28 PM
Igor
08-06-2007 09:39 AM
deputyski
04-03-2005 09:01 PM
Quick Reply: lift kits
