Less back pressure 12wg, 14 or 16
Old 02-25-2007, 06:00 PM
crankbender's Avatar
Which one of these would provide the most flow/least back pressure on a stage 4 HTT upgaded turbo? ... I am guessing the 16?
Would a 12wg out flow a 14 non wg?
Also will the 14 or 16 keep the boost pressure below 35 psi on the stage 4 while on a 12valve in say the 320 - 350hp range?
I have the stage 4 compressor housing and wheel and sitting in the box. When I go to put it on I was thinking about putting a larger exaust housing on as well. Obvously the 14wg would be the best but it cost 500 cnd$ and I realy don't feel like spending that much on my old junker just for a small gain in spool or top end over the cheaper housing.
Old 02-25-2007, 10:21 PM
Ponci's Avatar
A better ballance would be to port out a 14cm housing. That way it would be quick to respond and flow plenty on top.
dzl_damon
04-22-2010 10:48 PM
10fords
35
04-12-2009 11:31 AM
jmccart
07-17-2008 10:05 AM
jcb
03-04-2007 01:33 PM
JoshPeters
04-03-2005 08:13 AM
Quick Reply: Less back pressure 12wg, 14 or 16
