Leaky inj pump
Old 06-29-2007, 07:52 PM
Jethrro's Avatar
Leaky inj pump
Just bumped the timing on the rig today and somehow I have a leaky throttle shaft. Well since I have to pull the pump top to replace the O ring seal was wondering if it is absoultly necessarry to retard the timing on the pump to do this. Thanks Jethrro
Old 06-30-2007, 12:28 AM
Micaiahfied's Avatar
first i would pull the throttle shaft and reinstall it correctly. i had one leak after doing something so i pulled it and reinstalled it, never had a problem again... you have to make sure it's pulled to the correct height.
Old 06-30-2007, 12:43 AM
edwinsmith's Avatar
Received 1,036 Likes on 761 Posts
Once you have the pump top off the throttle shaft o-ring is real easy to replace. Just mark the timing position when you move the pump. Be sure you loosen the bolt in the bracket in the back or you'll have a heck of a time moving the pump.
Edwin
Old 06-30-2007, 06:12 AM
It's a whole lot easier to work with the pump retarded all the way. 3 nuts and a bolt will save you a lot of hassle.
RussianVolk
06-29-2010 01:13 AM
Jim5870
01-25-2010 11:29 PM
janb
03-25-2007 07:48 PM
9 sec camaro
20
08-26-2006 01:30 PM
hotmopr
06-29-2006 10:22 PM
Quick Reply: Leaky inj pump
