Leaks everywhere
Leaks everywhere
This is my 3rd CTD and this one is leaking from the common rail banjo fittings and the power steering pump. Has anyone else had these leaks and are they a common thing on the 05's
Sounds like the box you're running is making too much rail pressure. The good thing is that there is a little gasket that is most likely the culprit and it only costs about $2.00 and 5 minutes to replace it. Don't know about the PS leak...
Took it in yesterday and it was just a loose fitting. and the PS pump is leaking around the pulley shaft. they ordered one. I didn't want to tighten the fitting myself as I didn't want to over tighten it and they blame me for it's failure. But its fixed now. Just bothers me at 15000 miles this would come loose.
CCOUGHRAN
125
08-18-2004 07:23 PM
