leaking radiator valve.
Old 11-20-2006, 01:25 PM
onemoretruck's Avatar
I had to drain some coolant and cannot get the rad. draining valve stopping leaking some.
I have tried opening/closing many times thinking there might be a small debris located in there keeping it from sealing good but didn't work!
I had to use pliers to crack it open and rotated it half turn..was this OK?
Might need a new one but find it strange it goes that easy..altough it is 12 years old..
thanks,Ron.
Old 11-20-2006, 06:53 PM
infidel's Avatar
There is a 10¢ o-ring on the drain that's probably shot. Turn the drain a quarter turn and pull it all the way out. Run down to the parts store for a new one. You will lose most of your coolant, be prepared.
8liter
09-22-2012 10:19 AM
longbed
03-17-2006 03:57 PM
gottahavediesel
12-25-2005 06:55 AM
Kass
08-31-2005 05:37 AM
Carnage
10-20-2004 02:31 PM
Quick Reply: leaking radiator valve.
