leaking fuel?
Old 12-13-2004, 03:08 PM
Kman9090's Avatar
leaking fuel?
I have a 04.5 3500 Dodge Ram with the 600 series engine. I have about 20000 miles on it. Well I looked under it today and see that the oil pan has a wet spot around it. Well I start checking around for an oil leak and can't find anything so I go up top and start looking around and see that some of the wires plug into the engine have a wet spot around them so I figured out that it is diesel fuel. I really don't know much about these engines at all but the truck is still under warranty so it is going in tomorrow. I was wondering if anybody else has had this problem with the fuel leaking. Is it an injecter that is leaking or could it been the fuel line. Also should I worry much about this or is it just a common problem?
Old 12-13-2004, 06:57 PM
cquestad's Avatar
One of the lines...probably #5 or #6 is slightley loose.
Old 12-13-2004, 07:37 PM
Kman9090's Avatar
Thanks it has kinda got me a little wigged out because I need this truck this weekend to go on a little adventure so i'm hoping it is kinda small so the dealer can fix it tomorrow and have the truck ready for me tomorrow night.
Old 12-14-2004, 12:08 AM
gatf4's Avatar
Mine had the Fuel rail pressure sensor leaking, It sits in the fuel rail towads the front. The dealer had to order the part.
Old 12-15-2004, 10:06 PM
Kman9090's Avatar
they said that the fuel pressure sensor was leaking. It's starting to **** me off though. It's the 3rd day it's been in there and I called them today and they said that they got the part but didn't have time to put it on. When realisticly they had 3 hours to put it on. You would think they would be a little better with a customer that's all ready bought two trucks from them and will probably be back agian but I'm thinking I might try another dealer. I bet if it was their truck they would of had it done.
lilsuzuki4x4
09-01-2011 01:50 AM
diablo1
11-11-2008 10:30 PM
txasylum
03-22-2008 02:47 PM
Gumby
01-24-2005 01:15 PM
Quick Reply: leaking fuel?
