leaking fuel
Old 01-18-2008, 08:47 AM
taildragger's Avatar
leaking fuel
Alright, so when its cold outside (somewhere around 20*F) my truck starts to leak. In about 3 minutes today I had what looked like $0.50 of diesel on the ground under my engine where it was running down onto the front pig. Once the truck gets warm, I don't seem to notice any leakage.
Any ideas on this?
Old 01-18-2008, 10:21 AM
thewished's Avatar
Well my only experience is my lift pump leaked because there is a retaining ring inside that wears out but mine lost prime 4 or 5 times so maybe its fuel return line?? Hope it helps
Jered
Old 01-18-2008, 12:22 PM
Dartmouth 12V's Avatar
I would wipe down all surfaces where the diesel could be coming from and see where it shows up first. If the leak is before the lift pump, it won't leak when running(under negative gauge pressure) but it will also probably suck some air so the truck won't run as well.
Old 01-18-2008, 03:48 PM
TIMMY22's Avatar
I've had the fuel filter develop a pin hole more than one time.
I have no idea why but there would be a chip of paint missing from the bottom and a small enough hole to just drip a little fuel while it's running. change the filter an no more leaking.
Old 01-18-2008, 04:39 PM
John Faughn's Avatar
You need to narrow down that leak a lot closer to get info over the internet .
Pressure wash , dry , have someone under hood before starting , to watch many areas , metal lines to injectors , on side of main pump - between eng & pump , then going under intake manifold , down to heater prefilter , fuel filter , weep hole on side of lift pump .
Old 01-18-2008, 07:20 PM
strokerace's Avatar
Any ideas on this?
I would look at your lift pump and fuel lines, mine did the same thing.
What are you worried about $0.50 of diesel fuel is just a couple drops anymore, almost to small of a leak to see
lilsuzuki4x4
09-01-2011 01:50 AM
diablo1
11-11-2008 10:30 PM
txasylum
03-22-2008 02:47 PM
Gumby
01-24-2005 01:15 PM
Quick Reply: leaking fuel
