leaking coolant
Old 08-16-2006, 06:40 PM
wana12v's Avatar
leaking coolant
i ran the truck hard today and when i shut it off it started puking coolant. I discovered it only does it after I shut the truck off I can run it hard an let it idle and none leaks then I shut it off and it starts puking? it look like it's comming from the bottom passenger side?
Old 08-16-2006, 06:43 PM
singleturnout's Avatar
mine did the same thing found out there was a 4 inch crack in the block but mine was a 24v with the 53 block,woundnt leak while running but as soon as i shut it off then it would start dripping
Old 08-16-2006, 07:48 PM
bump
Old 08-17-2006, 06:38 AM
wana12v's Avatar
it's leaking from the radiator, i just dont get why it dosent start until the truck is turned off.
cutthroatxxx
17
05-22-2015 07:09 AM
fiveninefo
09-21-2011 12:02 AM
Mark Hodowanec
08-17-2009 11:56 AM
popeyesides
12-06-2004 03:43 PM
DTE
10-08-2004 07:02 AM
Quick Reply: leaking coolant
