LC(lasercuts) on 160 and 175 pumps
Pickin on the wrong admin...
I have read a few negative reveiws of running LC.I would assume that LC on a 215 pump maybe to much,but on the 160 and 175 pumps the LC may work a little better.I have a chance to try a set of LC.To keep fueling from going overboard,I was thinking of the tweaking the trucks fuel plate,star and smoke srew and even the boost adjustment.Anyone else with LC in there 160 and 175 try these adjustments to decrease smoke and EGT from using LC??Just a note...Going to try this on a stock HX35 turbo,#10 plate and 215 injectors..
Don't do it! You will not like them because they real hot and real smokey! I can live with a little smoke but the way Full cutts due a number on egts is a little much for me.With a stock turbo it would be much worse..
Thanks for the reply....So even with adjusting the other components, it looks like it may not be worth trying.....That is what I needed to know from others with 160 and 175 pumps....
ewatts2003
23
08-30-2006 06:07 PM
robert chilton
01-16-2006 02:44 PM
