Lamp Out Light
Old 10-23-2008, 06:53 PM
Stovetop535's Avatar
Lamp Out Light
Anybody know of any small/stupid light that might be out and causing the Lamp Out to light up on the dash?? I cannot figure out light is making it stay on.......
Old 10-23-2008, 07:20 PM
toptech72's Avatar
Have you checked all the brake and tail lamps. Mine kept popping on and all the lights worked when i checked them. So i just pulled and checked them all and found a brake light with a loose filament.
Old 10-23-2008, 10:02 PM
Yeah I checked the front headlights, low and high beams work, fog lights work, all of the clearance lights work, I just replaced the brake lights about 2 weeks ago when they both decided to go out on me. Also checked the turn signals, and brake lights and they all were working.
Old 10-24-2008, 08:09 AM
ThatGuy34's Avatar
third brake light? or maybe license plate lights
Old 10-24-2008, 09:05 AM
wyododge06's Avatar
Stover stop breaking your truck. I remember following you one day and your third brake light was out and I totally forgot to tell you about it. Good Luck at the game this weekend.
Old 10-24-2008, 09:26 PM
dont start with me scott...i fixed the brake light...ill check the licencse plate lights..hopefully that is it
Old 10-24-2008, 10:07 PM
vciesielski's Avatar
I know this is annoying but, recheck the rear lights (all connections) for burnt pins. Some times the rear light modules (the gray block) will burn in the connection to the individual lights. Dodge updated the light modules in late 04. They were about $14 a piece last year.
Old 10-25-2008, 12:11 AM
Jason_K's Avatar
i got the lamp light out light one time and it turned out to be my brake light
Old 10-25-2008, 10:29 PM
lumberman's Avatar
Something to ponder.... If the lamp out bulb blows, will the lamp out light still come on??
Mine did same one time. Finally found one of bulbs was not tight in plug socket. I switched bulbs and problem continued. Took a piece of plastic a wedged it in socket for tighter fit. fixed problem.
Old 10-26-2008, 03:34 PM
License plate lights are both working...tonight ill pull the brake lights back out and check the pins...does that light come on if there is a light out in the cab somewhere??
Old 10-26-2008, 10:15 PM
light out in the cab would be a no for me. we have two lights out in the cluster on the 03 and no lamp out
Old 10-27-2008, 09:03 PM
MIDNIGHTTRAIN's Avatar
what about your reverse lights will that cause the lamp out to come on?
Old 10-28-2008, 12:31 AM
All i can say is, it is possible. If they are suspect, check the light modules for burnt (or discoloration on/in) connections as said before.
Old 10-28-2008, 07:46 AM
Valv's Avatar
Start the truck but don't touch anything, no pedals, light off, etc.
Wait a few seconds to see if alarm goes off. Mine sometimes does it only when I turn left blinker or stop lights, since I have a bad pin on left taillamp connector.
Try each individual test (brake lights, blinkers, tail lights, etc).
Old 10-28-2008, 08:57 AM
ian515's Avatar
mine did the same thing recently. what happens when the lamp out comes on, and you hit the brake pedal?
Quick Reply: Lamp Out Light
