lamp out chime for no reason
Old 10-10-2006, 12:28 PM
danimal 95's Avatar
occasionally ill be driving with the lights off during the day,and the lamp out light will flicker and chime for no apparent reason,then go off after a short amount of time,any thoughts???
Old 10-10-2006, 12:48 PM
widelod's Avatar
On my 03 the rear connector had become slightly loose. Do a walk around unplug and re-plug the connectors
Old 10-10-2006, 02:19 PM
danimal 95's Avatar
thanks ill give that a shot its really annoying when it does happen
woodzy's Avatar
One of your lights in your tail light assemblies is most likely going out... Change all of them and it should go away.
Old 10-10-2006, 09:37 PM
hammerjammer's Avatar
In my case it was a dry socket,could also be loose bulb or loose connection. The computer senses a high resistance as a bad lamp.
Old 10-11-2006, 06:33 AM
Patriot2500's Avatar
Try cleaning out the connections with an air compressor? That would be my first thing to try.
Old 10-11-2006, 07:54 AM
Posm's Avatar
I had a brake light that was going out that drove me crazy for about a week. It would ding and then go out. I learned I could tap the brakes and make it go away. I would have replace every buld on the truck before I would listen to that again. It did burn out completly before I got home and it was easy to find.
When I replaced the buld, I put di-electric grease on the socket and on the taillight connector.
Bryan
Old 10-11-2006, 08:12 AM
Dan Marino's Avatar
Do what Posm said-that is the cure with the grease. I had to do this with both 03's
Old 10-11-2006, 08:35 AM
bowen's Avatar
Lamp out
Mine did the same thing and my problem was there was an open in the circuit board so you might want to check that.
Old 10-11-2006, 09:05 AM
danimal 95's Avatar
your trucks did this with no lights on or not using the brakes?
Old 10-11-2006, 11:36 AM
woodzy's Avatar
Mine would do it when the lights were off the first time, so I changed the bulbs that looked the worst. About a week later the chime came back, so I decided to change the rest. No probs since!
Old 10-12-2006, 08:53 AM
mule3010's Avatar
I had moisture in the left rear tail light plug dried it out and it's ok.
Joe
Hoss
21
12-03-2016 02:49 PM
ian515
09-25-2008 02:55 PM
sawboywv1
12-13-2007 07:45 PM
Buffalo
03-15-2006 05:26 PM
Quick Reply: lamp out chime for no reason
