Lackluster dyno
Something is VERY wrong. Is that corrected? Was the truck loaded (do they have a load cell?) what was the boost when you started and at the end of the run? What temps did you see? What kind of boost do you see on the street.
I can get that out of a Smarty, intake/exhaust combo with a stock turbo and sticks, so something is up.
Hmmm. Uncorrected. Not sure if they run a load cell. I can tell you it didn't seem like it ran the same as on the street but unfortunately my boost meter was not working. Egts didn't top 1325 while I can hit 1500 on the street. Dynoliscious on the iPhone puts my expected hp around the low 700's FWIW
Yeah 730-740's would be my guess. Did they brake at the beginning to try and build a little boost? I saw a truck that dynoes with us that had 150 stix, an edge hot, tow twins, and dual cp3's disappointed when he did 680ish. I would be looking for another dyno. Good luck
I vote dyno operator and my only dyno run I've ever done. Didn't think to check rail pressure but it hasn't been low on the street with the leak. All makes sense now without full boost it will still move the roller up to redline quick but not as quick as full boost.
DTR 1st Sergeant
For your setup, you will be best served with a 100psi total gauge and a 60psi cold pipe gauge. You are capable of hitting about 75-80 total psi and about 40-45 in the cold pipe. Of course, everybody's setup differs, but that is a range you are capable of.
Hmmm... Well it looks like I may be getting 20-25psi in the cold pipe. Haven't gotten the total psi installed just yet. What is the process for tuning the setup to get the cold pipe psi up?
