PDA
View Full Version : Lack of acceleration
crobtex
10-08-2002, 08:36 AM
???I have a '99 Ram 2500 diesel with a 5 speed. It has about 85k miles on it. <br>When the weather is hot, 85 up, the truck runs okay, but seems to accelerate a little slow. When it cools off to about 70 or so, it seems to accelerate much better. Could this be some kind of sensor problem?
Alan_Reagan
10-08-2002, 11:25 AM
Since it seems to be temp sensitive, it may be the Intake Air Temp sensor. They are from $18 to $30 at the dealer (depending on what he will do for you). Before you buy one, pull your old one out and clean it with brake cleaner.<br>A deep socket 13/16 spark plug socket will get it out for you.<br>Make sure when you are finished cleaning, that the blue &quot;bulb&quot; is not touching the brass case. Also, make sure the sensor is snug (not TIGHT) or you will lose boost pressure through the o-ring. Finally, since acceleration is down, tighten the boost hose clamps from the turbo to the intake. Make sure the fuel and air filters are clean.<br><br>Find Number 7 on the following link diagram:<br><br>http://www.dodgeram.org/tech/dsl/mt_2_feb98/fuel_sys_comp.htm<br><br>
10-08-2002, 11:28 AM
Welcome to DTR crobtex, hope you are enjoying the site and are learning alot more about your truck from us.
