Knicked rear main seal housing
Old 04-27-2007, 12:26 PM
Big Smoky's Avatar
I drilled 2 holes in the seal on opposite sides of each other and ended up knicking the metal housing on the outside of the seal. The knick goes past where the seal stops and I'm not sure it will seal. Has anyone done this? Will it seal or do I have to go get a whole new housing or is there a fix? Thanks.
Old 04-27-2007, 12:41 PM
Muddin_dude06's Avatar
I cracked mine on accident when pulling the old seal out I ended up having the replace that backing plate. The easiest way to change that seal is to take the backing plate completely off and work with it on a bench or something. If you don't get a new plate you could maybe throw a little bit of rtv around where the nick is. I would just et a new backing plate, it was like $40 and it was in stock...
Old 04-27-2007, 12:52 PM
Big Smoky's Avatar
Where did you get the backing plate? Dodge or Cummins? Because dodge tried to tell me the backing plate was all serviced seperate.
Old 04-27-2007, 02:23 PM
robert chilton's Avatar
Just get the part number off the old one and take that number to Cummins. They can hook you right up. Mine cracked when I was changing the rear seal. Ended up pulling the tranny a second time to replace the plate one cummins was opened again on monday.
ted_pulliam
08-04-2010 11:33 AM
bnold
07-07-2007 06:18 PM
chaikwa
03-24-2004 09:23 PM
okcummins
12-21-2003 07:45 PM
Mostwanted
09-17-2003 06:55 AM
Quick Reply: Knicked rear main seal housing
