Kinda scared
Old 06-23-2010, 03:10 PM
Joey62's Avatar
Kinda scared
Hey this is my first post I've been reading on here for a while and reading all this stuff and I'm kinda scared to do any thing to my stock truck in fear of really messing it up what could I do to have power but not mess it up
Old 06-23-2010, 03:22 PM
BigErksG2's Avatar
Fill out your signature so we can see what you have.
Old 06-23-2010, 08:49 PM
Joey62's Avatar
Ok got all the stuff bout my truck up so any sugestions would be helpfull
Old 06-23-2010, 09:06 PM
ellerman's Avatar
Almost all of the stuff about your truck, manual trans or auto? In my opinion, first get a good fuel pump(FASS or Airdog) then get an Edge Juice with Attitude so you can have more power and have gauges all in one.
Old 06-23-2010, 09:14 PM
Mike D's Avatar
Hey Joey, Someone gave me some good advice once. If you can't afford (monetarily or otherwise) to fix your truck, you should leave it alone. Of course I didn't listen.
Old 06-23-2010, 10:29 PM
Ozoneburner90's Avatar
1. fuel pressure guage 2. replace lift pump with an aftermarket one suck as a fass, airdog, or raptor. Then you can straight pipe it and add some other junk to it..
Old 06-23-2010, 10:44 PM
matthais's Avatar
lift pump will save you from failure in a stock truck
Old 06-24-2010, 02:02 AM
Joey62's Avatar
Ok so what y'all are sujusting is a fass file system edge juice with attuide and the edge will have the egt's and file presure becaus I want to give it a lot of power but do it the right way
Old 06-24-2010, 02:38 AM
Joey62's Avatar
Because with this truck money is not really a problem I just really want to it the right way
Old 06-24-2010, 08:27 AM
high bid's Avatar
1.gauges - egt, fuel pressure, boost, tranny temp
2. fuel pump upgrade of some kind - FASS, Glacier, holley blue etc
3. exhaust - 4" minimum,
4. intake - BHAF-Amsoil, AFE, etc
5. injectors - Mach 1.6, RV275
6. electronics - Smarty, Edge, Quad, could be moved up to #2/3
7. upgrade turbo
8. repeat #5 and #7 till you run out of $$$, time or are happy.
Old 06-24-2010, 08:48 AM
swordfish's Avatar
Don't neglect the Transmission. When you get up in power you will start to slip the stock transmission. Lots of reading on the forums on that topic.
I would definitely get the gauges one way or the other, especially fuel pressure. You don't want to have to put money into an injection pump if you don't have to.
I was like you, got here to the forum and was a newbie....I did a lot of reading and a lot of research. Just about any question you have has probably been answered a time or two on here already. Gain as much knowledge as you can so you are more confident with your truck and not as timid. If you are smart on your upgrades and the order you won't "mess up" your truck. Just my .02
swordfish
tfarmer96
01-16-2005 03:45 PM
DMH
01-11-2005 10:02 PM
Dodgezilla
09-29-2004 04:41 PM
tmiller24
02-19-2004 09:38 PM
BIG&BAD
03-11-2003 01:55 PM
Quick Reply: Kinda scared
