What kind of boost of you seeing?
Old 04-29-2007, 08:55 PM
Aosipower's Avatar
Thumbs up What kind of boost of you seeing?
Just wondering what everybody was seeing for boost numbers?
I have an HTT Quickdiesel 64/14 an with everything turned up I see 45psi. Just wanted to compare that to what everybody else is making! So if you would like to share what kind of turbo you have and what kind of boost you make with everything turned that would be awesome!
Old 04-29-2007, 09:46 PM
Registered
blackdiesel's Avatar
hit 52-54 psi on my sps 62 back in the day before i turned it down. when i installed the m6's i gained like 15 lbs of boost. kinda scary the first coupla times
but now im back down to ~20
Old 04-29-2007, 09:50 PM
dieselrob's Avatar
I get 45psi till the watse gate opens. From a dead stop i get 38 in 1st the the moment it hits 2nd its peged at 45 the rest of the gears and smoking a lot.
Old 04-29-2007, 10:01 PM
03qclb5spd's Avatar
55 psi with II Silver Bullet
Old 04-29-2007, 10:02 PM
ratsun's Avatar
70ish from my 35/12-3B26 combo
Old 04-30-2007, 12:24 AM
Ph4tty's Avatar
Used to see 47 lbs with my 64/14. Now I'm seeing around 35
Old 04-30-2007, 12:30 AM
inline6power's Avatar
really? wow, i hit 54-56 almost everday with my SPS 62/71/14 and i have hit 59 with it if i shut the wastegate all the way. have it wastegated now at 52. with my old SPS64/14, i was only able to hit 53 with the wastegate shut and everything on.
Old 04-30-2007, 01:49 AM
Ph4tty's Avatar
I'll be checking for leaks this weekend =\
Old 04-30-2007, 02:06 AM
Rodram2002's Avatar
I see about 65psi with my S300/S400 twins.
Old 04-30-2007, 02:49 AM
BCSCUMMINS's Avatar
I have my 62/71/14 wastegated at 55pis.
Old 04-30-2007, 10:20 AM
thats why i got my new spearco. i didnt think i had any leaks till i checked and i had a massive hole in my cooler that was beyond repair. never heard it because it was in the front lower right side but boy oh boy was it big.
Old 04-30-2007, 02:28 PM
74dart's Avatar
I run 40 untill the tc locks up but then I can see 46-48.
Old 04-30-2007, 04:25 PM
01 Dwhite's Avatar
wow im still seeing a very weak 28psi but i got the jhook comin in...could i run 45 psi on the stock studs and head gasket wit the PS 62/14? is it spool up quicker than stock or slightly slower?
Asa
Old 04-30-2007, 04:37 PM
dodgezilla04's Avatar
47 on my 62/14
Old 04-30-2007, 04:41 PM
paulb's Avatar
The same here. I have gone higher, but EGT's and E.T.'s were the same, so 65 is good!
Paul
Quick Reply: What kind of boost of you seeing?
