What kind of Anti-Freeze?
Old 10-04-2003, 08:08 PM
clifford's Avatar
What kind of after market anti-freeze can aguy use?
I have heard that you can't use (dex-cool) Do you have to buy the Dodge pink from them?
I have heard if you mix dex-cool with the green stuff it turns to jell-o.
Old 10-04-2003, 08:42 PM
quantrill88's Avatar
Re:What kind of Anti-Freeze?
heard the jello theory too and treat it as the truth just in case....
anyone got the facts on the anti-freeze deal?
Old 10-05-2003, 08:44 AM
yz
yz's Avatar
I just went to NAPA and bought there heavy duty anti-freeze. Make sure it is a low silicate formulation. But if you mix ethylene glycol with P***** (can't remember the spelling on that) glycol it will turn to jell-o.
Old 10-07-2003, 08:36 PM
doug60's Avatar
??? I have seen what can happen to a diesel engine if you dont use the proper antifreeze. Cavitation can pit its way through the cylinder liners in less then 30000 miles. I was told by my Cummins service manager that my 12 valve 5.9 does not have liners but cavation can also pit through cast iron. Dont fool around . Fully formulated
anti freeze is the way to go. Fleetguard or rotella ect. The extended life is only good for two years then sca's have to be added. [sca] supplemental coolant additives protect against cavation. Test strips are available from cummins. Some will say it is not necessary to use fully formulated on your dodge cummins I say why chance it. Just search cavitation you will get quite an education.
Old 10-07-2003, 10:29 PM
phox_mulder's Avatar
Easiest way to avoid any possible problems is go with Fleetguard.
Made by Cummins for the Cummins.
No questions, no worries.
Available over the counter at any Cummins distributor, or by mail order.
www.cummins.com or www.fleetguard.com
phox
Old 10-08-2003, 12:31 AM
SuperGewl's Avatar
You may want to pay closer attention to the anti-freeze that's in there, because the manual for mine has you use the pink stuff and not the green crap. Also if I remember correctly it's good for 5 years/100000 mile HOAT formula. ;D
Old 10-08-2003, 09:28 AM
RamDan03's Avatar
[quote author=SuperGewl link=board=20;threadid=20544;start=0#msg194280 date=1065591115]
[/quote]
That's correct. I've done some searching on the web and so far i've only found one good replacement that meets the requirements in the owner's manual. It is Zerex G-05 which is made by Valvoline. Here is a link to thier website.
http://www.valvoline.com/pages/produ...asp?product=10
Lyall
09-07-2006 06:38 AM
screaminbanana
06-02-2005 07:51 PM
Dodgezilla
06-22-2004 06:05 AM
DODGE4X4
04-09-2004 05:36 AM
Mark Thomas
07-17-2003 07:27 PM
Quick Reply: What kind of Anti-Freeze?
