killer pin
killer pin
should i fix my killer pin before i drive to alabama to get a load of hay.think i can do it in a day.cuz i like to leave next week.thanks
It sure would'nt hurt to atleast check it, if it could be changed in a day why not? Would be good insurance. When I had my truck worked on a while back I told the mechanic to check mine. It was good and tight, he went ahead and put a cap over it for me.
for the love of God if you have a day, DO IT
it should be against the law to chance the failure of a 6BT due to a loose KDP
loctite everything that could cause a problem
let Faith (wannadiesel) know you've done it so she can add it to her list of terminated KDPs
I would buy a new seal while you're in there... mine leaked all over. There are bolts as well that tend to get loose. I didn't take them out, just re-torqued them. Use the red loctite.
You might be luck or you may not. Today I did the KDP in the engine I'm putting in the crew cab project. The engine was never turned up by the former elderly owner who bought the truck new. The KDP at 52,000 actual miles was at the end of the bore. It wasn't loose and I drove it back in, made a 16 gauge sheet metal tab for it, and Loctited it in. All of the case bolts under the cover were tight and got removed and also Loctited. The only loose bolt was the front right outside corner. There was a tiny gear housing gasket leak in that same corner.
Pin didn't get me but an inner timing case bolt did.
I wouldn't stall on this job if I was in your boots.
A little labor is better than the $$$$ you will shell out for not doing it.
Good luck!!
Good luck!!
After unbolting the fan shroud take a thick piece of cardboard cut to the size of the radiator and tape it in place to act as a protection shield. It's cheaper than a replacement radiator.
I argued with them that this is clearly a manufacturing defect so they should tab that pin for free, but I got nowhere. I suspect Cummins long ago made a calculated decision not to repair any pins, but rather to simply replace those motors in which the pin let loose before the 7-year 70,000 mile warranty expired. Not an impressive way to conduct business; the fact they offer a tab is evidence they know there is a problem.
Unless it's untaxed, then it's red.
Ok I watchedall the you tube videos, I'm going to do this my self.
There has been debate over the kdp kits being a waste of money, I can grind a washer and buy my own loc tite.
Question is this: what parts materials do I really need to do this?
Big fender washer to customize
New timing cover gasket? Or just rtv? Both?
Wicking loc tite
Red loc tite
Beer?
Should i do the water pump while I'm in there?
Wicking loc tite
Red loc tite
Beer?
Wicking loc tite
Red loc tite
Beer?
Wicking loc tite
Red loc tite
Beer?
Wicking loc tite
Red loc tite
Beer?
Wicking loc tite
Red loc tite
Beer?
"I" would take out the rad. It is was easier to see and work in there without it and it gave me a good chance to have a look at all the components and give them a good clean. IE rads and intercooler and I inspected everything you can't see with all that stuff in the way.
I made my own gaskets and it was painless and saved me some coin.
If you "suspect" your water pump, change it. It beats ripping everything all apart again.
Be really careful of the wires of the crank sensor. They are brittle and can break or crack easy.
DO NOT FORGET TO LOCTITE THE INNER TIMING CASE BOLTS!!!!! Check out my thread on the devastation I ended up with.
I just printed off the sticky and it is all you need. A VERY well done format.
Have fun!!!!
Coffee for the repairs......beer for finished product.
