Kenworth/Peterbilt Shifter
i was wondering if i could use a Kenworth/Peterbilt shifter **** in my '96 CTD.
i haven't personally driven one of these big-rigs but i've ridden in them and i like the way that the shifter feels and looks.
i was looking at the shifter **** and was wondering if i could use the splitter gear actuater for my pac brake switch?
could it be done? i just thought it would be sweet if it could.
-Bryan
-Bryan
give it ashot u have nothing to lose....those shifter stick are really long...they'll come up to eye level in the dodge well almost....i think u might have ahard time replacing the entire stick with the springs doen there and all that but from that area up if u can bolt the pete stick on there somehow then go for it! and please provide pics on here i like this kinda stuff
Andrew
Andrew
The threads are different. **** on the Ram is metric. Other is standard.
Location: Lingleville TX but active duty Air Force all over the world currently
I have a eaton shifter on mine...with the splitter.......works great takes some "riggin" with a nut and some all thread....can be done works flawless and looks good with a long boot to go up to the ****...
what exactly did you mean when you said "takes some rigging with a nut and some all tread"?
do you have any pics of this setup?
thanks for the replys
does anyone know what the two treads are so that could get an adapter?
-Bryan
would you guy know where i could get a tread addapter from 10mmX1.5 to 1/2 course?
the rest i'm guessing i'll just have to play with.
Perkins, how did you do yours? have pics???
thanks
thanks
thanks
thanks
I have a Fuller shifter with two valves on mine. I am using the splitter valve for a 2-low control. The low range selector is going to control my engine brake. Because of the height of the **** I cut the top of the lever off and welded a 1/2" bolt into it. I also made my own short throw shift tower. Have been very pleased with the results.
"riggin" - take a piece of allthread and thread it into your "new" shift ****.
Then weld a nut that is the same size as the thread on your shifter onto the allthread and you will be able to screw your "new" shift **** onto your shifter OR
put a die on your shifter and make the threads the same size as the threads in your "new" shift ****.
dieselfuelonly
04-25-2009 01:39 PM
wadecool
32
08-31-2008 09:53 AM
