keeps stalling
Old May 17, 2003 | 09:49 PM
jlboren's Avatar
keeps stalling
they past couple of days my truck keeps stalling in gear after I let up off the pedal it does it warm or cold usually while steering or the ac is on is this normal?
Old May 17, 2003 | 10:23 PM
db's Avatar
db
Re:keeps stalling
Yes my 98.0 did at just under 200k. If it's like mine it would do it wether warm or cold. It would do it when I would tap the go pedal then release. I see you got a few miles on yours also.<br>A Cummins West guy told me why he thought it did and a possable fix.<br>He said that over time the injection pump throttle arm (on the back side of pump) wears out just enough to cause it to shut the fuel completely off for a split second on a hard return -then stall. He suggested to adjust the slack out of the linkage so it wouldn't &quot; over return &quot; &amp; to make sure the idle is set to the high side of the parameter.<br>I did &amp; been stall free ever since.<br>750-800 rpms in drive &amp; ac on for autos. Its a screw &amp; locknut on the rear of pump.<br>hope this helps <br>db
Old May 27, 2003 | 10:04 PM
jlboren's Avatar
Re:keeps stalling
adjusted idle no more problems now thanks
Old May 28, 2003 | 08:38 AM
Srigs's Avatar
Re:keeps stalling
I'll be doing this same fix this weekend. Thanks. 8)
Old Jun 2, 2003 | 08:38 PM
wiz-1's Avatar
Re:keeps stalling
had the same problem with mine and thats right. adjust the idol up and it will stop stalling
DC199512V87
Jul 21, 2012 11:57 PM
Txwelder
Dec 9, 2007 09:37 AM
tonyjsan
Jun 16, 2003 12:58 PM
pwabbott
23
Dec 19, 2002 09:51 PM
