Keeping the tank full
Old 10-21-2005, 03:45 PM
rico334's Avatar
I keep my truck as full if not completely full of diesel as much as possible. When it gets to about the 3/4 mark, I fill up again. (Also makes me think I am not spending as much money when I fill up........LOL)
Question is: Is this going to eventually lead to some disaster? I have read about algae growing in tanks, water developing and so on. With approximately ever 10 gallons of diesel that I pump in, I add one ounce of a diesel treatment solution that I purchase at the local Cummins diesel shop.
Thanks for any input.
Old 10-21-2005, 05:10 PM
bluebull's Avatar
On the 05's and newer a full tank is always better because it helps keep the lift pump cooler. A full tank on the 04's and earlier could help due to fuel being high enough in tank and the lift pump not having to pull so hard, this is very debatable though. Certainly no harm that I know of could come from having tank full all the time.
If your using an additive in the fuel you shouldn't have to worry about algie growth. I think algae growth is over rated unless you live by the sea, then it could be a major concern.
Old 10-21-2005, 07:48 PM
Geico266's Avatar
Keeping your tank full is a good thing. Your LP has less work to do, and less chance of condensate (water) accumulating in the tank also.
Old 10-23-2005, 07:02 PM
hovisimo's Avatar
if worse comes to worse the tank is not that hard to drop and clean.
i pumped mine out while doing the vent kit mod, accidentally hooked the pump up backwards and filled it full of waste oil. so yeah, it should be really clean. starting fluid, rags and a shop vac will make it like new.
Old 10-23-2005, 10:13 PM
bmoeller's Avatar
Unless you barely drive the truck, topping off at 3/4 tank is excessive. I fill up at 1/4 tank.
Old 10-24-2005, 07:59 AM
Geico266's Avatar
I'm filling up with coffee 3-4 times a day, stopping for fuel is no big deal. Keeping the tank full is a good idea to keep condensate out of the tank, especailly this time of year. Warm days, cool nights = water in the tank.
Old 10-24-2005, 09:56 PM
Equalizer 2's Avatar
I also fill up at about 200 to 300 miles on a tank. It sure makes it feel easier on the pocket $$$$$.
Old 10-25-2005, 08:29 AM
Thats MR Hoss to you buddy!
Hoss's Avatar
I fill up when the tank is empty.
Old 10-25-2005, 12:13 PM
signature600's Avatar
Ditto!
Last 5 tanks (3 weeks) have been $100+
Chris
Old 10-25-2005, 02:18 PM
herb's Avatar
Originally Posted by signature600
Ditto!
Chris
According to Jack Thorpe, thats a good thing
Old 10-25-2005, 02:39 PM
P.J
P.J's Avatar
He supports Big Business, must own stock in BP, Valero or Exxon/Mobile??
I too only fill up when I need to, add up the time and mileage pulling in and out of stations...............
Old 10-28-2005, 03:15 PM
Lee S's Avatar
I fill up at or before 3/4 full tank. Add a little Stanadyne and maybe some MMO. Full tanks are good.
Old 10-28-2005, 06:21 PM
04ctd's Avatar
The Myth of Condensation in Fuel Tanks
http://www.yachtsurvey.com/myth_of_c...fuel_tanks.htm
i run a couple gallons of gas in mine by mistake ever so often, that kills, cleans, and embarasses in fell swoop.
really, i think a few gallons of gas should be good to clean things up, add a quart of oil for lube, and put it on the spin cycle
Old 10-28-2005, 07:06 PM
Muted User
Dorkweed's Avatar
Location: "The Peoples Republic of Illinois".....behind enemy lines
Very interesting!!!!
Old 10-28-2005, 07:55 PM
RamWheelsBy4's Avatar
I might start filling up every day, those $100+ fillups are very depressing. Diesel bill this month is higher than the house note and I dont use the truck for business. That is just not right!!
Quick Reply: Keeping the tank full
