Kdp
Old 11-24-2010, 11:06 PM
DJ Turbo.'s Avatar
Kdp
I hate to admit this but what is a pyro gauge I have a idea but not sure and also whats the best Kdp kit to buy? if any one can answer this thanks again.
Old 11-24-2010, 11:11 PM
Onemoparnut's Avatar
A pyrometer measures exhaust gas temperature. And you don't need a kdp kit you just need a front crank seal and some good rtv gasket maker. Take the front cover off and just use a punch and a hammer to mushroom the aluminum housing and distort the hole slightly so that the pin cannot come out. Then replace the frons seal and put some rtv on the gasket and slap it all back together.
Old 11-24-2010, 11:15 PM
DJ Turbo.'s Avatar
how long will that last and can one not just remove the pin altogether?
Old 11-25-2010, 12:02 AM
Twisted Inc.'s Avatar
you could in theory remove the pin altogether but its nice to have if one ever has to remove the front gear case from the engine, not to mention the hassle it would be to remove the pin without dropping it into the gears or into the pan and not being able to find it, much easier to drive it all the way in and smash some metal over top so it can't come out and it should be good forever!
Old 11-25-2010, 12:07 AM
DJ Turbo.'s Avatar
is that what you did instead of paying for a kit?
Old 11-25-2010, 12:22 AM
i actually did that it made a little piece of steal to bolt over the pin, so double the protection....i was lucky enough to find a guy that had a longer bolt with the right threads, i also took each cover bolt that was inside the gear housing one at a time out and cleaned and lock tighted into place and re-torqued them.....you have to roll the engine over by hand to get to a couple of the bolts but there is a great how to article in the sticky section of this site
Old 11-25-2010, 12:27 AM
DJ Turbo.'s Avatar
sounds fun but i gyess one may as well work hard instead of paying later for not killing it
Old 11-25-2010, 07:58 AM
Jim5870's Avatar
Usually the cover comes off cleanly and the existing gasket can be re-used
even without sealant. Just need a new crank seal.
Old 11-25-2010, 10:03 AM
DJ Turbo.'s Avatar
okay so its something one can do easily at home right?
Old 11-25-2010, 10:25 AM
Yes it can easily be done at home only special tool needed is a torque wrench.
Old 11-25-2010, 10:29 AM
DJ Turbo.'s Avatar
okay I will prob get together with another 1st gen nut in my area who has done it already and get r done!!
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
SjLingenfelter
07-19-2003 05:14 PM
WalkingHorse77
03-19-2003 12:27 PM
gofastman
03-19-2003 10:29 AM
Quick Reply: Kdp
