Kdp problem again
Old 11-28-2011, 01:31 PM
cwebb710's Avatar
Kdp problem again
My kdp let loose huge chunk out of the INNER timing gear case. I j-b welded it now heres my questions found the pin itself can i reuse it? Also can i tab it myself with the welder? Also can i rtv the cover gasket instead of buying another gasket?
Old 11-28-2011, 01:44 PM
jstone44720's Avatar
RTV on the cover is fine.
There is really no need to put the pin or any pin back in to locate the case.
Old 11-28-2011, 01:45 PM
cwebb710's Avatar
Thats what im trying to find out if it has to be there or not
Old 11-28-2011, 11:41 PM
cwebb710's Avatar
Okay have cover back together and now i dont rember how to get the fan on i unbolted it from the block and dont know what bolts to use i belive there 10mm but i dont know if there all the same length and that on that right behind the pulley im at a loss with this truck already
Old 11-28-2011, 11:50 PM
Tate's Avatar
The dowels are there to keep the case from walking during operation. There is a big heavy pump that takes a significant amount of power to turn, it can and will walk even with the bolts tight.
Old 11-28-2011, 11:52 PM
cwebb710's Avatar
So i shoulda but the dowell back in? Cause if so im kinnda screwed
Old 11-29-2011, 07:40 AM
patdaly's Avatar
I would if it were mine........
Old 11-29-2011, 08:09 AM
Thank you Tate. I was told differently, but I trust what you are saying.
To CWEBB: I am sorry if this causes you grief. I was passing on what I have been told when looking into this for mine.
Old 11-29-2011, 10:15 AM
infidel's Avatar
Put it back in or buy a new one for a buck.
Many people have the misconception the pins (there are two) are only there to locate the case during assembly.
Cummins says they're there to keep the case from moving.
The bolt holes have slop and without the pins the timing gear and camshaft gear will push apart from each other leading to impossible to keep timing set and rapid gear wear.
Old 11-29-2011, 06:47 PM
rebal's Avatar
lock tight the bolts ,I have seen more bolts come loose then the KDPs and if the kdp is deep in the case just peen the hole over it wont ever come out again
Old 11-29-2011, 09:30 PM
cwebb710's Avatar
Alright well ill pull it back apart and replace the pin all the bolts have been out before so i think second time will go faster
Robert Rausch
01-18-2011 10:12 AM
Smokin96_12v
10-12-2009 07:39 AM
Steven K
06-04-2009 10:32 AM
b84u
02-20-2006 01:04 PM
gunracer1
18
11-24-2003 08:56 AM
Quick Reply: Kdp problem again
