The KDP and a question
Old 06-24-2007, 10:19 PM
jimlj's Avatar
I have read enough about the KDP to make me scared. I bought a '89 Dodge for the engine and trany for my project, but I don't know much of the history on the truck. Is there any way to know if the problem has already been taken care of short of pulling the timing cover off? I don't really want to tear into the engine, but I don't want to wish I would have. Can you see the problem child through the oil fill spout if you remove it and use a mirror through the hole?
Old 06-24-2007, 10:29 PM
edwinsmith's Avatar
Received 1,037 Likes on 762 Posts
I have read somewhere that the KDP isn't an issue on the 89 engine but I plan to do it eventually. I'm going to wait for a cooler day however.
Edwin
Old 06-24-2007, 11:01 PM
torquefan's Avatar
After removing the oil fill spout, all you can see is the injector pump gear, which is large and right up against the cover.
Old 06-25-2007, 12:51 AM
MrExtreme's Avatar
Edwin
I have a 6BT I pulled out of a 93 F600, (don't tell my Dodge it's new engine came from a Ford) when I tore it down for rings and bearings and Piers cam install, it did not have an alignment dowel pin, is this a Dodge only thing?
X
Old 06-25-2007, 01:31 AM
edwinsmith's Avatar
X
I think in later years Cummins made the timing housing with a blind hole for this reason.
Edwin
Old 06-25-2007, 07:15 AM
Bob Beauchaine's Avatar
Russian Roulet is still Russian Roulet. The dowel pin is an issue from '89 through '98.5. Not only that but the 5 bolts inside the outer cover that hold the front gear case cover to the the engine are also an issue. I've seen the results of the dowel pin comming out and/or one of the bolts comming out - cam broken into 3 pieces, 6 bent push rods and 3 broken lifters. It's about a 4 hour job to pull the front cover and take cars of the problem and who knows how long to fix the resultant damage caused by ignoring it.
Bob
Old 06-25-2007, 10:20 AM
rlyons's Avatar
Tab it and be sure, it is not worth it to leave it and hope it will not fall out.
Old 06-25-2007, 11:52 AM
G1625S's Avatar
My pin had not moved, but I'm glad I did it. With the engine in the truck it only took me about an hour to do it, and that includes making the ultra-high-tech coathanger tab and bolting it on
Old 06-25-2007, 10:25 PM
torquefan's Avatar
X
I personally know of a Ford medium duty truck with a 5.9 that had the KDP come out and do damage. Don't recall what year it was though. Maybe that was the difference. Looks like Dodge owners aren't the only "lucky" ones.
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
Thedieselkid
12-11-2007 07:29 PM
Ram of Steel
07-26-2007 01:41 PM
OHFarmboy
06-23-2006 08:59 PM
Quick Reply: The KDP and a question
