K&N filters
Old 05-31-2010, 07:31 PM
trust's Avatar
K&N filters
I'm sure this has been addressed but I couldn't find it. Im considering a drop in K&N air filter but am wondering if the benefit justifies the $80 local price. I have used them in the past primarily for their filtration benefits in dusty environs. My 01 is a 99% pavement truck that is about to head out on a long, (4000+) mile road trip and I'm wondering if there is any noticeable mileage or power benefit that I might see as a result of dropping in the K&N.
Also wondering if an exhaust change is worthwhile, mine is totally stock right now and I don't want to go crazy, and I certainly don't want more noise (I take enough crap over the stock noise level)
Thanks for the input
Old 05-31-2010, 08:03 PM
Administrator / Scooter Bum
Shovelhead's Avatar
I run K&N filters on my normally aspirated engines with good results (.i.e. no build-up of dirt/crud in the intake tract)
I used a K&N drop in on my Cummins for a short period of time, until I kept seeing dirt/dust/crud in the intake on my turbo.
Then I switched to a Scotty System and an UNI 2-stage filter.
No more crud.
Old 05-31-2010, 11:46 PM
Ed ke6bnl's Avatar
I wasn't going to use one but the truck came with it and the tube past the filter was so clean I continued to use it. ED
Old 06-01-2010, 09:27 PM
trust's Avatar
Thanks guys, I guess nobody is seeing anything one way or the other as to benefit to mileage or power and they generally do what they are supposed to
Old 06-01-2010, 10:22 PM
kreynolds's Avatar
Performance wise, gains are minimal. I ran a K&N for about a year. I saw no improvements in mpg. Maybe a little quicker spool up. Started seeing a little oil inside turbo inlet so I got rid of it. Now I'm using an Amisol nanofiber filter. I'm happy with it. FWIW, I never cleaned the K&N, so oil was not from improper cleaning.
Old 06-01-2010, 10:39 PM
I think I can... I think...
capt.Ron's Avatar
I saw a nice increase in boost and a pretty good drop in EGTs when I switched from stock to a drop in.
Old 06-02-2010, 01:54 AM
fourthandgoal's Avatar
I've got a stock air filter in mine now but the guy I bought it from gave me a k&n drop-in that I have yet to clean/re-oil and use. I was all excited about it until someone pointed out that, even with a better filtration system, more airflow probably means more dirt and the first thing it hits is your turbo.
I'll probably give it a shot and see what happens, but I'd rather take a slight decrease in performance than risk grinding up my turbo
Definitely interested in other brands to consider, as I'm sure k&n isn't the be-all end-all of air cleaners. Eventually I want to do a full cold-air anyway
Old 06-02-2010, 08:01 AM
nickg's Avatar
here is a link done by a couple guys over on the GM website it used a duramax as a test, results for K&N were not positive.
my own opinion is oiled filters get sucked dry, some claim they dont, each to his own I guess
http://www.dieselplace.com/forum/sho...d.php?t=117009
DodgeCowboy
07-23-2008 10:12 PM
bcfitzsimons
06-26-2008 12:17 PM
staarma
28
05-01-2008 11:10 AM
fitzydog
10-12-2007 10:23 AM
kelley15
08-20-2007 04:52 PM
Quick Reply: K&N filters
