just about out of the shop.
first let me thanks you guys for the info on the searches on this site it is truely alot of help and for your direct replies. a month ago i brought my brothers 97 one ton 4x4 into shop . nv4500 toasted from rear seal leaking. replace clutch turn flywheel install rebuilt nv4500 ( old one was two toasted to rebuild for me) also gutted transfere case and resealed it and reassembed . then onto the front of the engine . new radiator , new waterpump , thermostat, a/c pump, fan bearing and idler bearing and belt. then while installing upgrades on steering ( the bracket for the steering box extention bearing and the '03 trac bar kit) i found the ujoints in the front end were bad and axles were leaking 90wt. so new seals and ujoints. now to get a/c recharged tommorrow and off to line up shop. test drive a couple of weeks and back to the ranch. i have not worked on my cummins any amount its a first gen. i got all the info off this web site. again thank you ( by the way bill for parts used up the better part of 4.5k)
Well I am glad we were able to help, and sorry that the bill was so high. And after all that it should be good to go a long time without anything else, but oil
3500_CTD
13
01-29-2009 09:38 PM
UnrulyNFS
17
11-07-2007 04:20 PM
thxman
19
06-01-2007 10:16 PM
royta
02-11-2005 01:07 PM
