Just got my truck running and need help
Old 11-03-2010, 08:53 PM
sleeperman's Avatar
I just got my truck back togather and running I put head gaskets studs 60lb springs ats exhaust manifold twins(hx35/hx55) and some other small stuff and I got a used ip out of a junk yard and put on it. Now when I want to start it I have to use starting fluid to get it started but after its started it idles fine and runs good so what could be my problem? After I get it running I can shut it off and try to start it right back up and it still wont start with out starting fluid.
Old 11-03-2010, 10:05 PM
Sounds like air is getting into the system
Old 11-04-2010, 06:10 PM
sleeperman's Avatar
Whats the easiest way to find where it would be getting air?
Old 11-04-2010, 07:09 PM
Where the fuel is leaking out.
Seriously, if it won't start right back up without ether it's got to have a big leak!
Old 11-04-2010, 08:53 PM
sleeperman's Avatar
there is no fuel leaking anywhere even if i let it run in one spot it wont show a leak anywhere.if the pump if backed off in timing will it be hard to start but run fine?
Old 11-04-2010, 09:24 PM
Bencie's Avatar
Probably won't see a leak if its leaking on the suction side. It would be like sucking through a straw with a hole in it.
Old 11-05-2010, 12:26 PM
sleeperman's Avatar
if there was a leak on the suction side than when i shut it off it should start right up sence there is fuel in the pump already.
Old 11-05-2010, 08:33 PM
Put a little air pressure to the fuel tank, that will cause the leak to show itself more obviously.
Old 11-05-2010, 10:56 PM
sleeperman's Avatar
could there be something wrong in the pump to cause it in to start but run fine once started?
Old 11-06-2010, 01:36 AM
Received 1,331 Likes on 862 Posts
I agree...sounds like air. Check you oil level. If it's leaking out the front shaft seal on the IP then you won't "see" a fuel leak, but you could have one if your oil level is rising.
shaft
06-13-2011 07:50 AM
angrygoose
15
07-03-2009 09:38 PM
mullishacrew
04-27-2008 04:54 PM
Bobcat698
04-13-2006 09:12 AM
robox
08-04-2005 08:01 AM
Quick Reply: Just got my truck running and need help
