junk yard axle
Old 11-14-2010, 01:22 PM
90 power ram's Avatar
Smile junk yard axle
OK so i was roaming through the junk yard where i found a 1 ton Chevy that is a dump truck. i pulled the bed off so i could get all of the lifting stuff to manly put it on to my truck but i'm unsure of the axle that is in it it has nice wheels that don't have Chevy all over them and every thing is clean on it brakes look good but what would i be looking at to put that axle under my truck will it fit will it hold up to the Cummins, if i take the axle i will take every thing but tires. will this axle take the abuse and the big question i have is, is it posie. it looks like a 70-85 dump. i just want to make sure the guy said 20. bucks a wheel and 130 for the axle and then 25 for them ti pull it. so i'm looking at the cash but will it work on a d250 that has a 4x4 swap planed for it.
thanks Shane
Old 11-14-2010, 01:36 PM
freight train's Avatar
What size was the yoke? Our diesels use a 1410.
Im sure being its a dump its a dually. With that being said is it a c&c truck? Like on out trucks if you buy a c&c dually rear it will bolt in a regular D/W truck but will look funny because its not as wide as a regular rear end. I am not sure what rear it is just a couple things to look for.
Old 11-14-2010, 01:51 PM
im not really sure what kind of axle is it will have to go out and look on monday
Old 11-14-2010, 04:39 PM
dieselJon's Avatar
Sounds like a 14 bolt too.
beachboi
02-23-2007 05:17 PM
90firstgen
06-23-2006 03:26 AM
banzaitoyota
01-28-2006 11:47 AM
pwrtripls1
06-23-2005 06:35 PM
apache
04-26-2004 09:52 AM
Quick Reply: junk yard axle
