PDA
View Full Version : Juice w/Attitude not showing Oil Pressure
GizmoJoe
03-06-2008, 06:42 PM
I installed the Juice w/Attitude about a 1 1/2 years ago and the oil pressure never worked on this so I just shut the alert off. Something that I have always wanted to figure out why it's not working but was way down on the list. Spending time working on the truck this weekend and figured...OK...Let's finally get this straightened out.
I'm sure I just missed something...What was it???
Gizmo Joe
badme
03-06-2008, 08:28 PM
The edge gets the oil preasure from the truck harness. If everything else works I would say the problem is with the edge system. Mine lags a lot on start up. The guage in the truck shows good oil preasure while the edge still has the warning going off, but it only lasts for a few seconds at first start so I let it be.
tx_2500
03-07-2008, 04:14 PM
maybe yall should look at new IP sensors? when my edge didnt show boost i sent it back to them and wasted alot of time. turns out my map sensor was bad and as soon as i replaced it everything worked perfect. although it was nice that i bought the chip used and ended up with a brand new unit as a result, dont think its always gonna be the chips fault.
GizmoJoe
03-07-2008, 05:52 PM
I just wish I could get mine to show something other then zero. Everything else on the gauge is working other then oil.
I am still suprised with all the things that you can monitor on it. I have actually thought about putting guages on the pillar so I can set up the Attitude with other settings. Has anyone done this mod?
badme
03-07-2008, 08:07 PM
does the truck guage read oil preasure? If so the sending unit, wireing and guage in the truck work. So it is either the data stream from the computer on the truck or the edge system that is not working. Scan tool should tell you if the data stream is working and if it is it has to be the edge.
06er
03-07-2008, 10:00 PM
Iam gonna get the juice with attitude this week my oil pressure gauge in my truck dont work it always reads about 80psi as soon as the key is turned on so what do you think the attitude will read or wont it
badme
03-07-2008, 10:34 PM
depends on why it reads 80#s with key on engine off.
