Jet A in my tank.
Old 11-19-2010, 06:39 PM
mhuppertz's Avatar
Jet A in my tank.
One of my clients is a helicopter company. They are required to defuel their birds before they work on them, and are not allowed to reuse the fuel. I went there the other day and they had four, five gallon jugs waitinf got me. They also have a 500 gallon tank that is getting full, and it costs them to have it drained, so they offered that to me also.
I am currently running 20 gallons of Jet A added to about 5 gallons of K2 and a quart of 2-stroke oil. I'm hoping this is enough lubricity to keep from shelling my pump.
So far I am getting excellent mileage and it hardly smokes at all. THis worries me a little.
I don't know how to dertermine how much 2-stroke or motor oil I need to add to the Jet A to be safe.
Anyone know?
Old 11-19-2010, 06:49 PM
maybe368's Avatar
Anyone know?
Hi Mark, I believe that jet a is basically kerosene, which is basically a step above diesel on the refinement hierarchy. I would think that an oz per gallon would be enough. I have been wrong before, though...Mark here is a page that might help...
http://www.toad.net/~jsmeenen/fuel.html
You might be better off with 1.5 to 2 oz's of 2 cycle oil, I don't think too much will hurt...
Old 11-19-2010, 07:24 PM
Administrator/Jarhead
madhat's Avatar
Do a search, I've made a few posts on it. Search JP5 or JP8 in the titles, as well as Jet A .
Old 11-20-2010, 05:09 AM
JTCHess's Avatar
Not sure how Jet A compares to JP 8, but that is all the Army used in Germany back in the 90's when I was stationed there (I was a petroleum officer in the 3rd Armored Division and subsequently 1st Armored Division). Only issue was replacing the fuel filters more as like biodiesel JP 8 did a good job of cleaning the gunk out of the fuel system.
Old 11-20-2010, 08:27 AM
mhuppertz's Avatar
I have found lots of conflicting data, but from what I can gather Jet-A is K1, which means it burns more slowly and has less BTU's per pound, and does not have good oiling properties. Still don't know if a quart of 2-stroke oil per 20 gallons will keep my pump alive, but I can say that my exhaust temps have been totally fine and my mileage seems to be good. I will change my fuel filter soon though....
Old 11-20-2010, 10:54 AM
cougar's Avatar
I get Jet A from time to time. I won't run it any less than 1qt of motor oil per 5 gallon Jet A. And I limit that to 30% of the total mix in the tank.
Old 11-20-2010, 11:01 AM
mhuppertz's Avatar
Now I am worried again.
Old 11-20-2010, 12:24 PM
deanhinsley1963's Avatar
I would probably mix it 50/50 with diesel.
Old 11-20-2010, 01:42 PM
madhat's Avatar
Cummins says you can run up to 10% WMO, so just pour the two stroke to it.
On second thought... I can't comment on the first gen stuff very well... different injectors... different pump...
Old 11-20-2010, 02:51 PM
mhuppertz's Avatar
THe cool thing is becaus I have my timing so advanced, the truck actually runs better with Jet A. I can let me clutch out in 5th at 20MPH and it doesn't buck or bog, just grunts up to idle!
Old 11-25-2010, 12:29 PM
bigjohn92's Avatar
jet a
i have a friend that works for ERA when they defuel they put this stuff in large holding tanks he brings me 110 gallons at a time when he can get it . ive run a full tank few times with no problems. there out right now! good stuff a good product to add to is heres the website
http://www.fppf.com/lubricityplusfuelpower.asp
Old 11-25-2010, 09:28 PM
Boatnik's Avatar
If you don't want to run it send it my way.
Old 11-29-2010, 11:48 PM
MDCS's Avatar
MHUPPERTZ, i wouldn't loose a whole lot of sleep on it. A lot of FBOs run jet in their support equipment (fuel trucks and what have you). Our Eagle tug runs on jet-a and the only requirement is that it has a lubricity fuel filter. The filter leaches lubricant into the fuel as it filters. I can't imagine it releases any more lube than would equate to a pint of 2-stroke per tank full. If it concerns you, put 2 in. Cummins allows up to 5% used oil by volume for the 5.9l per their web site. Enjoy the free fuel!
jetlife
01-02-2008 08:03 PM
Sir Kaos
13
02-13-2006 09:56 AM
Zino
26
08-09-2003 01:01 AM
moneypit
22
07-10-2003 07:36 AM
spitzair
11-20-2002 12:08 AM
Quick Reply: Jet A in my tank.
