Jack points underneath truck
Just curious, is it ok to jack up the front end by putting a jack under the lower control arm mounts? What do you guys do?
I'd like to get all 4 wheels off the ground for tire rotation. For the rear I just use one jack in the center of the axle to get both rear wheels up.
same here, one side at a time. if i'm feeling lazy i just put the jack on the pumpkin and jack it real high until the lowest side is high enough, slide the stands in, then let 'er down . . .
mkinla
04-17-2011 08:06 PM
03CTDCO
23
05-05-2005 09:36 PM
