isspro ev2 fuel psi.
Old 11-20-2009, 06:58 PM
ZacMan5712's Avatar
just got some gauges a few weeks ago and my fuel pressure gauge bounces back and forth between 7 and 15 while idleing. is this normal? while cruising it hangs right at 12 but as soon as i stop at a light/stop sign it just bounces back and forth between 7 and 15. it's sort of annoying. any thoughts?
thanks
zach
Old 11-21-2009, 06:17 AM
ZacMan5712's Avatar
no one knows if this is normal or not?
Old 11-21-2009, 09:09 AM
Shank's Avatar
I have the same guage. Mine doesn't bounce at all. Reads 18psi. My guess is air in the line. It took me several trys to get the air out.
Old 12-01-2009, 04:29 PM
ZacMan5712's Avatar
well now it has been more than 10 days and still nothing has changed. could it be a bad gauge? maybe the wiring? any suggestions?
Old 12-02-2009, 05:52 PM
6 Shaker's Avatar
I had a problem like that with an Autometer that I used to run. It turned out that I had air in the line. Very difficult to bleed the air, but once it was bled the gauge read properly.
Old 12-02-2009, 11:20 PM
CD in NM's Avatar
My EV2 FP gauge bounces between 8-10 at idle, but stays right on when I am accelerating or crusing. I see you have an aftermarket fuel pump in your sig, maybe another question arises here - is this normal for that pump?
Have you tried to bleed your lines? I am supposing that you would want to do it at the engine? Loosen your line there and cycle your key a couple times?
CD
hawaiianbro
02-10-2011 07:52 PM
ZacMan5712
09-30-2009 04:14 PM
FBs555CTD
05-14-2009 10:01 PM
garbri
05-13-2009 11:18 AM
stroker101
03-13-2009 02:52 PM
Quick Reply: isspro ev2 fuel psi.
