russ300h
12-05-2005, 07:15 AM
Hi All, New to this site and so far I like it a lot. Hopeful I can get some ideas on a problem I have (had?).
I bought a '97 3500 5-speed about six months ago. It only had 115K on is and was in very nice shape. About three months ago (119K) I was traveling on a secondary road towing my trailer when I noticed a loss of power. I needed to keep downshifting to maintain speed and finally it died. Pushing the primer button on the lift pump then trying to start it showed it wanted to fire, but never really ran. Had it towed back to my place (yeah AAA!) and replaced the fuel filter and pre filter screen. It ran fine until a few weeks ago(122K). I was traveling a few hundred miles from home and went to shift. When I put the clutch in, the engine died. When I completed the shift and let the clutch up the engine started and ran fine. About fifty miles later while going up a hill, I had a severe loss of power and pulled over. Again the engine died when I put the clutch in. Got out and looked at the engine( why I don't know) everything seemed fine. Got back in and started it and it ran fine again. By then I was close to home so I just kept going. A few more times I lost power, but the engine kept running, then picked back up again. This time I installed a new transfer pump, bypass valve and replaced the rubber portion of the fuel lines to the engine. Took it for a fourty mile test ride and it ran like a Swiss watch.
I plan on going thousands of miles away next month and don't want to have a repeat while I'm at the mercy of some st ealer. Have these symptoms occured to anyone else? Is there ANYTHING I have left out that could possibly cause these symptoms to reoccur? My confidence in the truck is shaken and I won't put enough miles on it before I leave to feel comfortable.
Sorry if this is long, but I want to be as accurate as possible regarding the symptoms.
