intermitent block heater
Old 12-07-2003, 04:13 PM
jigdog's Avatar
Has anybody had any problems with getting their block heater to work every time you plug it in? I have used mine every year and sometimes it does not work and some times it does on the timer and off the timer. I may need to replace the plug on the end.
Old 12-07-2003, 04:18 PM
Commatoze's Avatar
Re:intermitent block heater
You might want to try and disconnect then re-connect where the cord goes into the heater. The ring unscrews, then pull the cord straight out from the heater. Then, hook it back up again. I've heard of a few other guys having the same troub.
Old 12-07-2003, 05:00 PM
jrs_dodge_diesel's Avatar
Definitely a connection problem. Heater elements either work or don't. You may just need to reseat the plug. Or just might be a bad plug.
Old 12-07-2003, 07:42 PM
jigdog's Avatar
thanks for the replys i did discon the cord from the block and try to seal the edge around the connect ring and thought that did it but it didn't. I think you guys are right that i need a new plug on the end. Every time it has not work i have plugged the drop light to it and it works . I guess it time for a new male end on the heater. Thanks agin.
Old 12-07-2003, 07:55 PM
Any chance that the connection is wet or dirty? That may be another cause that I can think about.
Old 12-08-2003, 07:26 PM
bkrukow's Avatar
I had the same exact thing last year. I put a new end on it and no more problerms.
Old 12-08-2003, 08:46 PM
jigdog's Avatar
BK thanks for the help i am getting a new end tommorow. ;D
Old 12-11-2003, 09:58 PM
jigdog's Avatar
bk-i put the new plug on and it works great again.
supersonictoys
11-08-2008 09:17 PM
win
07-13-2004 08:50 PM
Ravenwood220
04-04-2004 04:28 PM
kdionne
02-14-2004 04:38 PM
jdeereboy
08-21-2003 06:55 PM
Quick Reply: intermitent block heater
