interior lights
interior lights
ok it seems that if i have my dimmer switch on the normal position even when i close the doors the interior lights stay on. When this first happend me and my passenger would just open and close our doors and it would go off. but know they stay on no matter what. also with the doors open i press the switch to turn the lights off manualy and they still dont work. Hoping somebody has had this problem. Thanks in advanced
Chad
Chad
i am having this same problem and when it happens my power door locks will unlock but not lock when i use the button on the door but the kelyless works. This has been happening for about a month sometimes everything works fine then nothing works at all and i hears some clicking coming from under the dash thanks in advance
Does that model of truck have a delay timer for the interior lights? You might be able to find it in the fuse box section of your owners manual. It's possible that the timer is stuck on.
I had a problem like this in my 94, it wasnt electrical it was mechanical, what was happening was the door would actually push the whole switch in instead of the button. The switch in the door jamb is the one. An eight dolllar part from the dealer later, and it was fixed. You might check it
ehammett
13
12-30-2008 05:20 PM
proudpapa97
05-04-2008 06:50 PM
Vintage Empire
12-20-2005 10:02 AM
patriot pearl blue
12-29-2004 06:47 AM
CHarlan
08-06-2003 08:40 PM
