Int Wipers Cause Crank Sensor DTC, Misfire
This is an obscure problem I've been chasing for some time. Originally thought problem was related to water interfering with sensor signal. Then found it occurred when wipers set to intermittent, even when dry. Approximately every fourth or fifth cycle the engine will misfire and occasionally set the crank sensor DTC (forget #). I'm using Banks tuner. Anyone else experience something similar?
04ctd
29
11-03-2006 03:37 PM
Diesel Freak
05-03-2003 09:40 PM
