Installing springs & head bolts?
Old 12-22-2008, 10:04 AM
rock crawler's Avatar
If I am installing injectors how much more work is it to install springs and head bolts. With my mods would I even need them. I'm guessing I'll be running about 550hp.
Old 12-22-2008, 10:12 AM
Jason_K's Avatar
with all your mods, i would say that head studs and valve springs are a must. it's gonna be a good amout of work but it's better to do everything at the same time, instead of tearing it apart 3 different times
Old 12-22-2008, 11:27 AM
-PowerWagon-'s Avatar
If you use the Source tool for the springs you have to pull the injectors anyway.... It would be a great time to install the studs as well. Are they needed?.....how much more do you plan on doing?
Old 12-22-2008, 11:33 AM
I don't plan on doing anything else to the truck after these mods are done. If I do the springs I will probably have to have someone else do them. This may be above my mechanical level. External stuff is a snap but I don't feel real comfortable with internal motor stuff. I will be doing the injectors though. I just hate paying someone to do something I can do myself. That is why I did most of the mods myself. Tranny and internal engine stuff I don't mess with.
Old 12-22-2008, 11:50 AM
rip 112's Avatar
If you can afford it, i would say go for it. I would and I will eventually.
Old 12-22-2008, 12:12 PM
Honestly....if your not seeing high boost (50+) on a regular basis, or high RPM.... I don't think it's necessary. I will say if you can pull injectors... springs should not bee a problem. If you were planning twins some day I would say go ahead and do it while she's open..... but it can be done anytime.
Old 12-22-2008, 01:09 PM
rip 112's Avatar
But how many ppl do you know that would be satisfied at a certain hp level? On this forum? After reading all this hype up on hp #s and boost #s? I thought 500hp would be my limit and I'm happy for now, but I already see a heavier duty clutch in my future, and what the heck, might as well put it to use! I would do it for safeguard, you never know when it will be of benefit to you. That's why I said if you can afford it, do it.
Old 12-22-2008, 01:56 PM
mpracehemi's Avatar
I'm in the middle of the mods. myself. IF you are doing the inj. yourself, springs are ALOT easier. I bought the spring tool, all you do is bring the piston up to the top of the particular spring set and compress to pull out the locks, the valves are held by the piston. Switch out springs, re-install locks-done!! That's a easy install. The spring tool is $165-170 shipped, can't exactl remember. Buying tools is NEVER a bad thing.............
Old 12-22-2008, 04:09 PM
Termite 06's Avatar
I agree with everyone so far. Springs are wicked easy once you have the injectors out. You may not need them now but you might decide to up the hp in the future and you will be happy that you have taken the safety precautions ahead of time. As for head studs, these are slightly more difficult but still pretty easy if you take your time. I did head studs and valve springs all while I was waiting for Don to send me my injectors. I got all of the information I needed to do these things from the helpful people on DTR.
Old 12-22-2008, 04:11 PM
Termite 06's Avatar
also, if you decide to do the valve springs, check with your local dealership to see if you can borrow their compressor tool. My dealership just took a copy of my I.D. and let me take the tool for the weekend.
Old 12-22-2008, 05:36 PM
metal_miner's Avatar
Right.....
Old 12-22-2008, 06:58 PM
Originally Posted by JStieger
Right.....
OK,OK! I don't think I will ever be able to afford to do anything else after all this stuff. I'm tapped out for a LOOONG time.
Old 12-22-2008, 07:41 PM
mudder500's Avatar
Im doing mine this weekend. Got a cummins valve spring tool. Should be interesting
Old 12-22-2008, 08:40 PM
dslpwr81's Avatar
Does someone have detailed instructions or maybe visuals (which are easier for me) on replacing injectors, springs, and studs?????? If you do, please pm or email huntenmaniac@yahoo.com. I would REALLY apreciate it. Thanks
Jason
Old 12-22-2008, 08:52 PM
Pooter's Avatar
Heres a pretty good little install writeup from ole Shane...
http://www.cumminsforum.com/forum/3r...s-springs.html
Quick Reply: Installing springs & head bolts?
