installing A pillar pod
I am a little confused on installing instructions. There are 2 papers, one shows to install it over the original pillar cover, the other paper says to replace original pillar cover I purchased from Glowshift. Probably no tech support till monday. Has anyone had experience with this. I am working on a 2001 installing triple gauges with speaker hole.
You may have more luck in the 2nd gen forum.
I just did one last week. You will have to cut out the raised speaker hole so the new gauge piller will fit over it correctly. It attachses over the original and is held in place with plastic push in's, or screws, and the original piller cover holds it all in place using the original clips.
EdmontonCanada
11-27-2008 07:15 AM
1320
08-19-2003 11:20 AM
