Installing Isspro pyrometer
Old 06-30-2007, 10:28 PM
goronimal's Avatar
I was wondering if anyone knew how far the probe sets inside the exhaust manifold,can`t find any specs.
Old 06-30-2007, 11:37 PM
BearKiller's Avatar
So long as the tip is in the heat, but not touching the bottom, it should be okay.
The threaded hole in my manifold is 1/8NPT, while the thread on my probe is 1/4NPT.
I had to use a 1/8NPT nipple, with a 1/8 x 1/4 bell coupling adapter.
My pyro works fine with this set-up.
Old 07-01-2007, 12:32 AM
dpuckett's Avatar
I think the PDR website recommends about 1/3-1/2" protrusion into the exhaust stream. I dropped it to the bottom, then brought it back up about 1-1/2".
Daniel
Old 07-01-2007, 08:32 AM
BearKiller's Avatar
Daniel
You must have a different style than I have.
My probe is ISSPRO, but is of a set length; it can only go as far as the threads permit.
Old 07-01-2007, 09:42 AM
DanMan's Avatar
Mine is like dpuckett's. The probe is infinitely adjustable for depth, then you tighten the collar and it's locked in place. I'll take a pic of it later. I got mine from DieselManor.
Old 07-01-2007, 12:16 PM
dpuckett's Avatar
Yup, mine has a ferrule and compression nut, and is (was) infinitely adjustable. Now that I have tightened it up on 3 different trucks, it is kinda stuck in place.
DP
Old 07-01-2007, 12:55 PM
ripping r's Avatar
x2. just have not got mine in yet.
Old 07-01-2007, 02:12 PM
DanMan's Avatar
I had mine for over a month before I got up the courage to drill into the exhaust manifold!
Old 07-01-2007, 04:50 PM
goronimal's Avatar
I installed my pyrometer,boost guage and an hx-35.Everything went well and everything works.Thanks for the info.Now it time to dig into the inj. pump.
rip 112
20
11-01-2008 06:30 PM
eric13
04-10-2008 07:48 PM
Shootist
03-04-2005 10:26 PM
kelley15
10-09-2004 04:46 PM
bigredbrick
11-07-2003 11:47 PM
Quick Reply: Installing Isspro pyrometer
