Installing EGT probe. Anyone use a tread sealer with it?
Old 06-29-2007, 07:01 AM
RoadDiesel's Avatar
I'll finally get to my EGT gauge installed this weekend. I will be drilling into the manifold, and was wondering if anyone has used some type of sealer on the probe treads...(autometer gauge) I will also use the drill & grease method, even maybe engine idle to keep the metal shaving out..thanks
Old 06-29-2007, 07:26 AM
WS6HUMMER's Avatar
I didnt, the instructions didnt call for it either. Dont have any leaks or problems, dont know how well teflon would hold up around 1100 degrees either.
Old 06-29-2007, 09:16 AM
schoust's Avatar
Ahh no thread seale,not sure it would last very long before it went up in smoke...
Old 06-29-2007, 09:22 AM
Administrator / Scooter Bum
Shovelhead's Avatar
I used anti-seize on mine.
Old 06-29-2007, 09:38 AM
Captain's Avatar
same here. All I used was copper antisieze (higher temp raiting then nickle) havnt had any leak on either truck and I did the 1 truck twice when I replaced the manifold.
Old 06-29-2007, 10:13 AM
JD730's Avatar
Yup, anti-seize and nothing else. Never had a problem taking one out either.
Old 06-29-2007, 10:18 AM
Mike Stowe's Avatar
I just did mine yesterday, and didn't think it would be a good idea for thread sealer. It's a pipe thread, so the hole actually ends up being tapered, resulting in a good seal.
I drilled and tapped mine with greased bits and with the engine idling. Wear safetly glasses and gloves (it gets a little warm, but not bad) and take your time. Piece of cake.
Old 06-29-2007, 11:52 PM
JSPulliam21's Avatar
anti seize!
shonne
08-25-2009 12:27 AM
Rollink2
42
04-03-2008 06:29 PM
Oneloudblaze302
10-07-2007 12:41 AM
BigBlueDodge
10-30-2006 07:18 PM
Quick Reply: Installing EGT probe. Anyone use a tread sealer with it?
