Installed new fuel shutoff solenoid, now have power problems...
Lets see if you guys can figure this one out. Here's the whole story, About a month ago my fuel shutoff solenoid on my 89 W-250 burned up driving down the road and shut the truck down. I gutted it, rigged up a manual shutoff cable, no big deal. Finally ordered a new shutoff solenoid, got it yesterday and installed it, no big deal. I started the truck up, it fired and shutoff. Tried again, same results so I gave it some throttle, it fired right up, stayed running. Let off the throttle, engine rpm slowed down as I let up on the throttle, when I came all the way off it it shut down. Somehow, my idle got changed, so I adjusted the idle everything seems good, but when driven on the highway, Im lacking some power and about 8 lbs of boost less than before I changed the solenoid. I've looked everywhere for a good answer to this, just for kicks I pulled the solenoid out again and looked at everything, reinstalled, same results. I guess next Im going to try putting the old gutted one back in and see what happens but its acting like the throttle index is off, but it or nothing else other than what is necessary to get to the fuel shutoff solenoid is touched. Any ideas?
BTW the truck runs smooth no smoke, not even black smoke anymore. It ran fine with the old solenoid and with the old one gutted was about the same. Now with the new one Im lacking power. I still have the old solenoid and the spring and plunger out of it, just the electrical part burnt up. Thanks for the help
How would you do that? im guessing pulling it out and hooking it up and turning the key on. Im wondering if the plunger isnt a different length if that would cause it?
Dang Jason, You give up on us?
Did you try what we talked about on the phone?
Since the stock plunger was still OK and it was just the electrical part that burned up can you swap plungers adn see if the length makes a difference?
No I havent tried re indexing the throttle yet. It shouldnt be that but who knows lately. Everytime I try something with that truck I cause myself more problems it seems like. Im gonna pull it apart again tomorrow and try the other plunger. Its got to be something with that since thats how it all started. I dont like my truck being like its stock again
So todays experiments included taking the new shutoff solenoid back out, comparing the length of the plungers, they were the same, testing the solenoid and it sucked the plunger all the way in, taking the spring and plunger out and reinstalling, no change, and bleeding the injector lines incase some air got in, no change whatsoever.
92smokin blacky
10-26-2011 08:41 PM
mytrucksaslug
06-02-2008 10:16 AM
cumminsdriver635
09-27-2005 10:35 PM
