Installed HTT 64/65/13ss!!!!
Old 08-04-2009, 11:26 PM
ModManiac's Avatar
Off with the stock charger and on with the HTT, Ive only had it on for a few hours and its been raining like crazy. I really like the way this turbo spools, it seems to be a little slower than stock but when it gets going it has great power. Im pretty impressed with this turbo, I think it will be a great turbo for towing as well. The install took about three hours without removing the manifold and was pretty easy. I highly recommend the 64/6513ss to anyone looking for a quick spooling turbo that doesnt want to give up alot of low end. This turbo has a much more noticible sound as well, and the power is very smooth from it. I have tried it on stock programming and it will spool but a tad slow but can easily see 30psi, with my predator on extreme it will hit 42 no problem. Thanks to Rip, Jmccart, and Homewrecker for all the help.
Old 08-05-2009, 07:36 AM
KKB
KKB's Avatar
Hope you like it. That same turbo on my truck was too laggy for me with my tight converter. Once it did spool it took off with a lot of top end compared to the stocker, but towing 15k fifth wheel I couldn't keep temps where I wanted. The stocker was much better for me, but with your 6 speed you should be fine. I decided to take it off on a hot afternoon when going about 57mph with converter locked up and went to pass a vehicle and smoked out the entire highway and it felt like I couldn't get around the guy, but at 65ish it lit and I was gone, but from 57 to 65 waty to slow to spool for me.
Old 08-05-2009, 09:56 AM
AH64ID's Avatar
Good deal.. That is my dream turbo.. and figure since I am doing a cam and 50hp nozzles in the spring I should be able to spool that sucker faster than stock.
Old 08-05-2009, 10:47 AM
rip 112's Avatar
Matt it will only get better!!! Give it some time to break in and you will notice it spoolup quicker and quicker. That 6 spd will really get it going too. Hope you enjoy it man!!!
Old 08-05-2009, 11:30 AM
homewrecker's Avatar
Glad to hear you got one! I'm sure your gonna love it.
Old 08-05-2009, 11:49 AM
ModManiac's Avatar
If you are doing a cam and 50hp tips I would almost going a little bigger, but there is no doubt that it would definately spool the 64/65 quick!
Old 08-05-2009, 11:57 AM
rock crawler's Avatar
I think you will like it. I have the same one and it does seem to spool slower than stock. But when it spools up, hang on.
Old 08-05-2009, 12:58 PM
TexasCTD's Avatar
I have been considering this one too, but after reading this and other reports of slower than stock spooling..........I think im going to have to go for the stocker/s400 twins.
In the heat we are having here lately, I smoke even on the stocker. If I put on the same 64/65/13ss turbo....I bet I would be smoking out the highway too. My truck can put out some smoke.
I would imagine the stocker/s400 twins would spool like stock but give me more top end and much better cooling. Only speculating here.
Old 08-05-2009, 01:26 PM
mpracehemi's Avatar
XX22 the guy is already swapping tips, might as well put at least 90's even 120's since he has a man. trans. and can control egt's better on the low end by keeping the r's up along with boost.
In a few months I'll be going for bigger twins and stixs, I was curious on the 64 for the top and with my mods, I think I'll be okay when I do tow 14K trailer/cars.
Old 08-05-2009, 02:36 PM
AH64ID's Avatar
Its not all about power, but towing and economy.... If I could take the fuel economy of 50's and get 0's I would :-)
I also live at altitude, so its a toss up between the 62 or the 64.. I don't want to have to worry about it when towing at 6k feet. But a 6x/65/13ss is a good turbo regardless.
Old 08-07-2009, 04:37 PM
Jordan5687's Avatar
I just installed the 62/13/65ss HTT I love it! Oh and 50hp DDP nozzles, and boost fooler, and intake horn. It's amazing, lots of top end, I can punch it in 5th gear going 55-60mph, and see 75-80mph in a flash, shift in 6th and floor it and see 95 in another flash lol. It was a little slow without the nozzles but still good on top end the nozzles just made it come alive! I'm very pleased with that turbo, and a big thanks to all who helped in my decision!
Old 08-07-2009, 05:14 PM
fordassassin's Avatar
I had a 64/71/13. Spool was a tad slower than stock. EGT's were hotter cruising, but @ WOT they were cooler. I had the 64/71/13 with stock stixs and also Flux 3's.
The 65 impeller keeps egt's cooler while cruising, but @ WOT they would get a little hotter. While the 71 impeller would keep egt's cooler @ WOT rather than cruising.
Stock Stixs with 64/71/13
http://www.youtube.com/watch?v=3CKSZT5KwyE
http://www.youtube.com/watch?v=rZ-YlDLGTcE
Flux 3's and 64/71/13with a torn rubber boot(big boost leak)Smarty TNT/r with Edge EZ. Only level # 4.
http://www.youtube.com/watch?v=O0Y5IOclEUg
http://www.youtube.com/watch?v=qPwmiQiTA8s
http://www.youtube.com/watch?v=x4E6kwofVZs
http://www.youtube.com/watch?v=r0AttK2yaMU
Old 08-07-2009, 07:28 PM
Bswope's Avatar
Since your doing those things id go with the 71 over the 65 for sure, cam and sticks will spool that thing like stock!!! I have a Hamilton cam on its way and cant wait to get it in!!!
Old 08-08-2009, 10:00 PM
Hows your truck holding up Buddy?
Old 08-09-2009, 09:26 AM
Bswope's Avatar
Joey its doing good man, but I have this rattle on bottom end that I cant figure out, once boost hits about 20psi it goes away and everythings sounds nice and smooth, its driving me nuts. But the truck runs great and everything just have this mysterious rattle......
Fire Rescue124
10-09-2009 11:20 AM
Derek Roch
34
09-20-2009 05:03 PM
Jason_K
13
05-11-2009 08:55 AM
O.T
16
01-14-2008 02:47 PM
95ram12v
01-13-2008 07:48 PM
Quick Reply: Installed HTT 64/65/13ss!!!!
