Installed GFS NO FUEL PRESSURE need help!
Old 08-25-2007, 11:15 AM
sqrl$$'s Avatar
Question Installed GFS NO FUEL PRESSURE need help!
I have a 2004.5 that I just installed the GFS-392 kit with the big line kit. I have the quad r/p and fuel pressure gauge. Truck started up fine, and I could hear the pump priming the system up. When I got the truck started I am reading no fuel pressure on the quad. Truck runs great, just no fuel pressure reading. I was getting 5-6 at idle with the stock pump and it would go to 0 when I mashed on it. Now showing 0 all the time. Any ideas?
Old 08-25-2007, 02:30 PM
sqrl$$'s Avatar
figured it out. The quad fuel pressure sender has to be grounded to the chassy when you use the big line kit. Works like a charm now and I am showing 15-16 lbs at idle.
Old 08-25-2007, 02:31 PM
Pooter's Avatar
Originally Posted by sqrl$$
figured it out. The quad fuel pressure gauge has to be grounded to the chassy when you use the big line kit. Works like a charm now and I am showing 15-16 lbs at idle.
Cool, good to hear you figured it out.
(AND good info to know!)
Old 08-25-2007, 02:50 PM
sqrl$$'s Avatar
I had to edit my post, I meant to say ground the fuel sender unit, not the gauge. Talked with Richard at Glacier and he said this is something he will have to add an adendum to for anyone using the big line kit with the quad r/p and fuel gauge.
beaver76
07-26-2007 07:53 PM
bhuffstutter
15
03-27-2007 08:41 PM
SSminnow
15
01-14-2007 04:09 PM
The_Mexican
27
11-13-2006 02:52 PM
acook
09-11-2006 06:25 PM
Quick Reply: Installed GFS NO FUEL PRESSURE need help!
