installed edge with attitude moniter tonight
Old 12-31-2004, 12:18 AM
lightening ram's Avatar
Talking installed edge with attitude moniter tonight
when i first started my truck the check engine light came on and had a p0500 code but it went off, cant really test it too well here in the north roads suck so all i can tell you is its a nice install, and you can adjust lots of stuff including trans slip,it will defuel when any max parameters are met, so far its a cool toy and feels ok for as hard i caould push my truck, ill keep you posted as the week goes by.
Old 12-31-2004, 01:53 AM
RUSSELLMAG's Avatar
I had a code that went off as well after installing the juice and monitor. I took it into the shop I deal with, they have a test ECU computer from Dodge. The code was a speed sensor code. The code occcured after I programed my tire size in the monitor and went for a drive. We then brought the digital speed odometer in view on the monitor and found out the the monitor was giving us the wrong speed that the truck was actually going. We finally programmed the number for 265's and the speed matched. The light hasn't came on since. We also figured that the ECU circuit board might of not liked something it saw and the light turned on. Anyway the juice and EZ are one heck of a stack!!!!
Old 12-31-2004, 05:33 PM
triplenickel's Avatar
lightening ram if you don't mind me asking, where did you get it and how much?
Old 01-01-2005, 01:14 AM
yea your right russelmag it is a speed sensor code but it went away and never came back, it works good, but i have no where to try it to the fullest potential, tried to put the hammer down this morning but almost died on the highway lol, spun all 4 wheels the weather has sucked for a while so till it smartens up i have nothing else to report.
Old 01-01-2005, 02:03 PM
RUSSELLMAG's Avatar
Well I hammerd down yesterday and pulled another code. P0016-Camshaft/Crankshaft misalignment. This would of been expected, since the timming is so advanced on the extreme setting. I will have to get with edge on Monday to see what the deal is. Having that light on bugs me. It finally smokes!!!! I pulls so hard from 45-90. I have some real fun next week with the TC/VB is installed. I will keep you posted on the outcome of this CODE problem.
Old 01-02-2005, 12:26 AM
thanks russel if anything happens in the mean time i will keep you guys posted, also do you have the 600 or 555 ft lb engine?if you have the older engine i was told that there was still bugs to work out in the edge, they couldnt even get any edge chips with monitor for the 305hp engine at this time, only the 325 hp ones were ready for production, just what edge said.
Old 01-02-2005, 01:20 AM
RUSSELLMAG's Avatar
I have the 04.5 with the 600. I will talk to EDGE on Monday and let you know.
mcctho21
13
10-10-2006 05:12 PM
DISTURBED
09-17-2006 08:46 PM
Dusty Ratcliff
04-23-2006 09:36 AM
razor6
04-21-2006 04:59 PM
Quick Reply: installed edge with attitude moniter tonight
