Installed boost controller
I used a ball spring stlye boost controller now I have 28 pounds of boost and exh temps do not go over 900 they used to climb rapidly to 1200 + when the boost shut down at 18 pounds.I used this style because I liked the way you can adjust it and I think it will work more accurately .I used a Hallman ES.
http://www.boostcontroller.com/index...26category%3D5
i made my own and it only cost me $7 at the hardware store. its adjustable just like that and is smaller, looks better, and and from the looks of that one mine hooks up better. but now i just keep it all the way closed and get about 35psi with stock turbo and injectors.
Do you have to do anything else to the truck to get 35psi? In other words, do you need a chip or other type of boost fooler to not throw codes or something?
I'm guessing this is in place of a J-hook.... Also, what size ID is the hose and barb fitting? It looks like 3/8" hose....
Hoss
12-29-2012 08:57 AM
klx650a2
06-23-2009 01:46 PM
SS1156
11-02-2008 10:25 PM
Bradtothebone
04-10-2003 08:28 AM
