Install Gauges? EGT/Pyrometer
Old 04-04-2007, 07:15 PM
boyeraz's Avatar
I am looking at buying and installing a set of gauges for my 07.
Auto Meter
Pyometer/EGT
Trans Temp
Boost
My question is how hard are they to install?
I know the Pyometer/EGT gauge you need to drill and tap.
Old 04-04-2007, 09:24 PM
boyeraz's Avatar
Anyone?
Old 04-04-2007, 09:31 PM
tritont's Avatar
if you are some what mechanically inclined you shouldn't have a problem. Most kits or gauges come with all the instruction you need to get the job done.
One suggestion.... you might want to look into Isspro or Dipicol gauges as they both match the OEM cluster and both emit green light like the OEM gauges.
this is a great place to make your purchases. One reason being, Geno's makes sure you have everything needed to do the installs. A banjo bolt is one thing that most will charge you extra for. It comes with Geno's gauges.
http://www.genosgarage.com/departments.asp?dept=192
Old 04-04-2007, 10:42 PM
ShutupAndHoldOn's Avatar
I bought some an Autometer 3 gauge A-pillar kit. My local Dodge dealer installed it in an hour and a half. My Pyro went into the Jake so there was no drilling needed.
Old 04-04-2007, 10:44 PM
Luvnacumns's Avatar
Autometer's are ok.. I am installing mine right now.. I would recommend buying the kit from geno's or diesel manor.. I bought mine locally to support the small town shop but coulda saved money and bought the Issso's of Dipro's from Dieselmanor for about half the cost.. by the time I get all the rest of the crap to install it... Autometer's are good guages though I like them ...
They are fairly easy to install..
Shane
Old 04-04-2007, 11:35 PM
boyeraz's Avatar
What if my truck has no jake brake?
Will I still need to drill? Or can I buy a kit for no drilling?
Old 04-04-2007, 11:38 PM
3500lly's Avatar
You will have to drill and tap it, but don't worry it's not that bad just make sure you have a strong drill and bit cause that manifold is pretty hard.
Old 04-04-2007, 11:50 PM
Fisherguy's Avatar
Check out my gallery for pics and info on the install.
It's not too bad if you're a mechanical person...
Old 04-05-2007, 04:21 AM
darrenb's Avatar
is tapping into jake brake recommended? is it just as reliable as the manifold?
Old 04-05-2007, 06:25 AM
3500lly's Avatar
manifold is considered by most to be the best location
Old 04-05-2007, 09:35 AM
yfz450guy's Avatar
why not just tap the number 6 tube?
Old 04-05-2007, 09:55 AM
jrussell's Avatar
https://www.dieseltruckresource.com/...d.php?t=144907
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
Duckman1993
09-12-2006 07:50 PM
YFZ
07-27-2005 10:53 PM
Altaboy
07-21-2003 11:43 PM
Quick Reply: Install Gauges? EGT/Pyrometer
