Inlet thread size on Filter Canister
Old 07-31-2008, 01:30 AM
bcool's Avatar
I'm looking for the tread size/pitch on the canister. I'm collecting all my AN fittings and i need one to adapt from -6 to the canister but I'm not sure if its going to end up being an o-ring fitting or a pipe thread fitting.
Thanks,
Brendan
Old 07-31-2008, 02:29 AM
Don Wagner's Avatar
M12x1.50 no o-ring needed, use thread compound.
Old 07-31-2008, 02:47 AM
Tate's Avatar
Usually a sealing washer is used. Less messy than sealing compound.
Old 07-31-2008, 01:46 PM
Don Wagner's Avatar
With Glacier fittings I use the sealing washers, with Earl's fittings I use thread compound.
Old 07-31-2008, 06:02 PM
HOHN's Avatar
I'd recommend an ORB fitting if possible. Avoid sealing compounds if possible-- they aren't as bad as teflon tape, but they are still good to avoid.
O-rings are generally the best option to pursue if it's a choice you have.
STORM fittings will seal better than banjos and you don't have the hassle of fuel contamination (tape or goop) or lost washers.
jmo
It's not like I'm a fuel system engineer for Cummins or anything.
Wait-- I actually am
That was for you, Don
Old 07-31-2008, 11:09 PM
Don Wagner's Avatar
Finally, a return sarcastic verbal joust, I've been waiting.
Old 08-01-2008, 11:40 AM
Mike D's Avatar
Put a Cummins logo on a guy's paycheck and he think he's an expert.
I knew you and Don would make good buddies.
I've talked with Don on the phone and he's a real nice guy FWIW... He didn't even get mad when we returned his "books" in a different configuration after he sent them to us. Thanks for those by the way. I'm enjoying my copies.
Old 08-01-2008, 01:13 PM
Don Wagner's Avatar
Glad you and Brian were happy with the "info", hope to get down there in October. Even though I am a fan of sarcastic rhetoric, I don't think I will be receiving a Christmas Card.
Old 08-01-2008, 01:24 PM
Mike D's Avatar
I hope it works out so you can make it, it's always a good time for everyone. We'll make Brian buy the beer.
Old 08-01-2008, 04:42 PM
HOHN's Avatar
You guys crack me up! I am fan of sarcasm too-- I think Don and I are in some ways birds of a feather. Well, with the minor exception that he knows a ton more than me, but aside from that little trifle.....
Old 08-02-2008, 01:39 PM
Don Wagner's Avatar
I like the new signature by the way.
royta
03-18-2010 05:33 AM
schoust
10-21-2009 10:09 AM
mpracehemi
09-21-2008 04:35 AM
RonP
05-28-2007 02:15 PM
Scotty
11-04-2005 10:02 AM
Quick Reply: Inlet thread size on Filter Canister
