Injectors w/my stack and cp3
Im going to be getting some Dynomite 90HP nozzles, i was told that with those i wouldnt be able to run my stacked boxes (crazy larry and EZ)because i have a stock CP3. Is this true? Will my power level with those injectors minus the EZ be more or less then the stack and stock injectors
Winner winner chicken dinner!
Had ATS stage 2 110hp sticks without a modded pump, and felt like I lost some power. I didnt have a rail gauge at the time, but the truck would surge at high rpm. Changed to Flux 3's and got a stage 2 CP3 from floor it and the truck is a beast now. I wouldnt reccomend anything above 40-50, but hey ask they company you are getting the sticks from, they should know the flow rate and be able to tell you for sure.
all cp3 are not crerated equal,some stock pumps with good fuel supply and pressure will keep up but most will not,with a stock cp3 and crazy larry and 2flow injects it would keep up with 3 flow injects it wouldnt keep up
adamsmarshall
13
10-07-2008 06:54 PM
Jethro6213
19
07-11-2008 11:59 AM
BADBOWTIE
28
07-14-2007 02:36 PM
megacabrule
33
05-10-2007 01:07 PM
