What Injectors?
Old 08-21-2007, 07:54 PM
tweeder_51's Avatar
What Injectors?
Im about ready to get some injectors, Im looking for some around 100 horses. What would be best for my truck? I will probably stop after injectors. Im on a college budget too. Should I try goin with nozzels or not?
Old 08-21-2007, 08:27 PM
JStull's Avatar
I had good luck with jammer tips on my '01 truck. I installed them myself but did have them pop tested before installation. I really liked the Jammers for performance and price.
Jason
Old 08-21-2007, 08:28 PM
MSquare's Avatar
Call Lenny or Ross at DDP. www.dynomitediesel.com
Old 08-21-2007, 08:30 PM
J7 Diesel's Avatar
I assume your budget is tight so tips are going to be your cheapest route but if you want good full injectors jammers are good and inexpensive.
Pm on the way...
Old 08-22-2007, 02:22 AM
HOHN's Avatar
Good advice. The F1s I have a wonderful sticks, but they are expensive.
The DDP sticks are probably the best performance you can get at a little lower cost.
jh
Old 08-22-2007, 06:49 AM
one54ton's Avatar
Id go with jammers nozzles as well. They arent tough to assemble either.
Old 08-22-2007, 07:18 AM
CARR's Avatar
He said he is on a budget
Old 08-22-2007, 07:51 AM
Mike D's Avatar
That's kind of rude, don't you think?
MSquare is offering his opinion as to what he considers a budget performance injector, yet you call him a dummy?
Maybe you're the
Old 08-22-2007, 08:58 AM
J BODY's Avatar
Maybe you're the
......looks like two guys have commented on the expense so far. But then again...when I was in college a diesel truck was way out of the budget in itself. All depends on what the "posters" money situation is......
Old 08-22-2007, 09:38 AM
tweeder_51's Avatar
Ok guys, thaks for the help. As far as the $ goes there really isnt a set amount, just tryin to spend as little as possible so I can still pay for my truck, apartment, tuition, food and bills.
Old 08-22-2007, 09:40 AM
RonA's Avatar
I had a set of Scheid lightning injectors at one time. I think they are under $600.Rated at around 100hp. I've always found DDP injectors to be very smokey for the amount of power increase. But my setup is different. I prefer F1 injectors for a couple reasons. They run smoother in my truck than the Scheid or the DDP injectors. Don can make injectors for a specific goal and get them right the first try. But the most important thing to me is that a used set of Mach injectors is always worth more an any other brand. I've had 11 sets of injectors so far. I have traded in Jammer1's and 2's as cores because I couldn't get more for them than the core charge for a new set.
Old 08-22-2007, 10:04 AM
Mike D's Avatar
Carr had no clue what tweeder_51's budget was... and he called MSquare a dummy for his suggestion to use the DPP injectors. Maybe tweeder_51's college budget is $1000? He didn't say... Never the less, I think it was out of line for the dummy icon. Maybe I'm a dummy for say anything.
Good luck tweeder_51 with whatever injector you choose.
Old 08-22-2007, 10:34 AM
getblown5.9's Avatar
I love my DDP's, and Lenny is one of the coolest guys to deal with.
The smoke is VERY low for level of injector I am running, and the power gained is more than what the advertised power was. I picked up roughly 180hp at the rear wheels with DDP 150hp injectors on a stock HO pump.
I am now running a custom made size from Lenny that are in the 250HP+ range and I can drive smoke free with the smarty on 9 if i want to. I havent tried without the smarty, but im sure the smoke would never be a problem unless I purposely lugged the engine.
Old 08-22-2007, 10:45 AM
RonA's Avatar
250hp injectors with no smoke. That's fantastic.
Old 08-22-2007, 11:00 AM
If you want proof here it is
drag racing
http://www.youtube.com/watch?v=JQwSP6OdK54
pulling
http://www.youtube.com/watch?v=suiu7...e=user&search=
Quick Reply: What Injectors?
