injector test problem?
Old Aug 3, 2009 | 08:45 PM
MDLP412's Avatar
i have a snap on scanner at work and hooked it up to my truck and ran a test that shuts off one cylinder injector at a time, ive never done it on a common rail and was wondering about the results. when ever one cylinder got shut down the RPMs started fluctuating up and down really bad from anywhere around 650-1700 RPMs with no throttle input. is this suppose to happen? and if its not does anyone know what is happening?
Old Aug 3, 2009 | 10:06 PM
mwdean's Avatar
rpm should drop somewhat, not a lot. when you have no drop in rpm you've found the dead inj
Old Aug 3, 2009 | 10:19 PM
BigIron70's Avatar
Cummins Guru
Are you using a 8.2 MODIS ELITE INDUSTRIAL? That's a nice scanner but expensive, may need Cummins software update which is also very pricey.
Old Aug 4, 2009 | 04:02 PM
MDLP412's Avatar
that makes sense, i dont think we have that
Haulin_in_Dixie
Sep 17, 2005 11:36 PM
NoSmokeNoGo
21
Feb 4, 2005 11:50 AM
